Reply 100 of 166, by Bondi
- Oldbie
ericvids wrote on 2021-10-25, 20:45:I wasn't getting this error, and I spent a few hours trying to reproduce your problem, then I realized something: I've seen the […]
Bondi wrote on 2021-10-25, 14:04:Digital sound is working now, as well as adlib music (did not copy MIDI folder yet). Cool! But the game crashes sometimes now wi […]
But the game crashes sometimes now with this message (mostly after I kill someboby)
IMG_3259.jpgEdit. Also noticed that Wolf3d detects the card as Sound Blaster now (it was detected as Adlib before)
I wasn't getting this error, and I spent a few hours trying to reproduce your problem, then I realized something: I've seen the error before. It was when I tried to use the registered version EXE on shareware data files.
So I copied over the shareware files, and sure enough, it gave me the same exact error. 😜
I've uploaded both registered and shareware versions so you can see which one works with your setup properly. (Are you using .WL1 data files? Those are shareware.)
ALSO: I've got Covox support working on this build (I think). Do you have the hardware to test it? If so, the way to enable it is to add the SS# parameter to WOLF3DSW.EXE with # corresponding to your parallel port. (So if you plugged it into LPT2, you'd enter "WOLF3DSW SS2"). Then make sure Covox/Sound Source is selected in the Sound menu.
AND ALSO: Since the MPU-401 component is just one feature out of many at this point (and as Bondi eventually found out, wolfdosmpu works without the MIDI files in place and just reverts to OPL2 music), I am considering changing the name of the project to just "wolfdos". What do you guys think? 😀 It can't be "fastwolf" (like fastdoom) because it isn't faster. 😉 (Also, I probably won't rename the exe files since the suffixes are pretty descriptive, with M describing "music/minimum fixes" and W describing the WASD controls.)
Oh, sorry you spent so much time because of my stupidity. I have different versions on different laptops.
I have a covox and will be able to test it later during today.
And please don't change the names. i think we got used to them, and changing will lead even more confusion.
