First post, by HUN_s912
All DOS games run fines. Music, SFX it's OK.
Only Golden Axe that uses pc speaker to SFX. Midi music is OK (SB-pro).
I tried several options (beep and beep2.com; moslo; setmui).
Is there a way to run axe in real DOS with digital SFX?
Or that is just possible in DOSbox?
Some "code hack" maybe help? 😀
http://www.reteam.org/papers/e76.pdf
Reply 3 of 4, by wbahnassi
You can connect PC speaker output to your SB Pro. This way you will listen to both sfx and music from the same output speakers. I personally prefer the raw sound of the PC tweeter against it being amplified and bass-enhanced through my speakers. It just didn't sound like what I grew up with.
Reply 4 of 4, by HUN_s912
wbahnassi wrote on 2022-09-07, 13:06:
I have motherboard crystal audio https://theretroweb.com/motherboard/image/v66 … 29799157843.jpg, not really pro 🙁
But very nice solution, thankyou.
