Golden Axe SFX
First post, by HUN_s912
All DOS games run fines. Music, SFX it's OK.
Only Golden Axe that uses pc speaker to SFX. Midi music is OK (SB-pro).
I tried several options (beep and beep2.com; moslo; setmui).
Is there a way to run axe in real DOS with digital SFX?
Or that is just possible in DOSbox?
Some "code hack" maybe help? 😀
http://www.reteam.org/papers/e76.pdf
Reply 1 of 4, by konc
Golden Axe doesn't have sound blaster sfx.
Yes it has adlib music but only pc-speaker sound effects.
Reply 2 of 4, by HUN_s912
konc wrote on 2022-09-07, 12:55:
Thank you.
"Hack it up the beast" 😀
Reply 3 of 4, by wbahnassi
You can connect PC speaker output to your SB Pro. This way you will listen to both sfx and music from the same output speakers. I personally prefer the raw sound of the PC tweeter against it being amplified and bass-enhanced through my speakers. It just didn't sound like what I grew up with.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 4 of 4, by HUN_s912
wbahnassi wrote on 2022-09-07, 13:06:
I have motherboard crystal audio https://theretroweb.com/motherboard/image/v66 … 29799157843.jpg, not really pro 🙁
But very nice solution, thankyou.
