First post, by BEEN_Nath_58
- l33t
I usually play all of my CD/DVD based games on Windows 11 through Daemon Tools and using no-CDs wherever required.
The problem came after a restart. Windows 11 no longer allows mounting of files. I used Daemon Tools, it complaints about insufficient resources, Windows Explorer iso mounting fails, UltraISO and Alcohol 120% (it even fails to set a disk drive letter) does nothing.
I will be surprised if they decide to remove disk image supports, since their own OS is shared using them.
In any case, what other options do you recommend me? Since not every type of data can be accessed by just opening a disk image file (such as music data through WinRAR or UltraISO), what alternative would I use to get the same functionality as mounting a file.
