First post, by ananananas
I didn't quite realize Windows 3.11 "operating system" would be this unstable: change anything, and it will stop working.
So, is there a way to modify settings from within the DOS? I know C:\Windows\Setup.exe and Autoexec.bat but is there anything else? Or a DOS tool or something?
Reply 2 of 4, by maxtherabbit
you can always edit system.ini and win.ini too
Reply 3 of 4, by Jo22
Also win.ini and system.ini.
Registry also exists, but is rarely needed.
Other files like midimap.cfg, control.ini, progman.ini or winfile.ini etc usually don't stop Windows from starting.
Reply 4 of 4, by ananananas
Yeah, system.ini did the trick for recovering from some network driver related issue. Need to check those others too, thanks!
