First post, by bushmac
Recently purchased the Windows 95 native version of Road Rash (1996). Installed and started up fine on my Windows 98 SE machine, but when I go to the actual racing screen, there's a great deal of flickering occurring on screen. Any idea what could be causing this? Thanks for your time.
Reply 1 of 13, by Davros
see if theres anyway to limit the framerate or try vysnc
ps: it appears to run fin on win 7 if you end the explorer process if you have a modern pc
Reply 2 of 13, by VirtuaIceMan
I know Road Rash requires you to pick your MIDI driver carefully or the music won't play during races and an alert will pop up before the race begins. Might be that. Otherwise perhaps it's a virus checker/firewall alert popping up on the desktop behind the game? I don't recall much flickering on Win98 or XP.
Reply 3 of 13, by filipetolhuizen
If we knew your Win98SE system config we could have a better idea on what's causing this.
Reply 4 of 13, by bushmac
My computer config:
OS: Windows 98 SE 4.10.2222 A
256 MB Ram
AMD K-6 300 Mhz
Nvidia GeForce 2 MX (PCI)
Sound Blaster Live! (SB0200) (PCI)
40 GB IDE HDD
1280 x 720 desktop resolution using a Samsung Syncmaster driver
Also recently upgraded processor to a AMD K6-2 550 Mhz (underclocked to 450 Mhz due to motherboard restrictions and possibly drawing too much power from power supply). With this CPU, game will lock up at the racing screen in any resolution.
Reply 5 of 13, by bushmac
Flickering on the 300 Mhz setup also only occurred in the 640 x 480 resolution. In the lower rez mode, game runs fine (sound and all).
Reply 6 of 13, by filipetolhuizen
Try different nvidia drivers. Some of them had bugs on Win9x.
Reply 7 of 13, by bushmac
@filipetolhuizen: Just rolled back to the version 45.23 drivers for Win9x. Flicker issue resolved (solved my flicker problems and models poping in and out in X-Wing vs Tie fighter under 3D acceleration mode as well. WOOT!)! Still have the lock up issue with the 500 Mhz processor installed, but I'm replacing that CPU anyway, so we'll see. Thanks for the help everyone.
Reply 8 of 13, by filipetolhuizen
I'm glad you found the driver that suited you best. I had my best experience with the driver version 29.42 back when I had a Geforce 3.
Reply 9 of 13, by bushmac
Good news is the flicker issue seems to be resolved. Now the game locks up every time I enter a race no matter what resolution the game is set at. So far I've tried disconnecting my Sidewinder 3d pro, rolling back the graphics drivers further (nvidia 29.42), and gone back to my 300 mhz processor. Any other ideas?
Reply 10 of 13, by bushmac
OK, figured out why Road Rash was locking up. When I'm using my Sound Blaster Live! (SB0200) (PCI) as the sound device, the game locks up. When I switched back to my on-board sound device, runs fine. So there you go: the Dell OEM Sound Blaster card sucks a lot. Doesn't emulate too well in Dos either.
Reply 11 of 13, by filipetolhuizen
Do you have the latest Liveware installed for the Live? There is also a small driver update for it.
Reply 12 of 13, by VirtuaIceMan
If it just makes a "bonk" error noise when then game starts it's probably a MIDI error as I mentioned. Try pressing space or enter and see if it works then without music.
Reply 13 of 13, by bushmac
@filipetolhuizen: Yah, I installed the latest Liveware drivers. Same result. I'm going to be changing to an ISA sound card for DOS applications, so this should not (in theory) be the issue. I've found a number of problems with Dos emulation and program compatibility with this particular Sound Blaster card.
@VirtuaIceMan: Unfortunately, I was not receiving an error or "bong" noise indicating an error from Windows. The entire system would lock up (unable to access task manager, return to Windows Desktop, zero feedback from the machine via mouse and keyboard, etc.), requiring a hard boot to restart the system. Thank you for the idea, though.
