First post, by Demo85
Have a bunch of older games from my childhood i'm going back to replay, with DgVoodoo most of them just work and look great. My only issue is EAX support. I'm using onboard sound on my Asus Z270g Mobo and I know I gotta install OpenAl and Alchemy which I did but whatever file/reg edit to make Alchemy load on PCs without it is seemingly lost to time. Every link I find turns out to be a dead link. Does anyone have the info/files I need to get this to work?
If all else fails i'd be willing to buy a Sound Blaster to get EAX working, Which model should I be looking for to get EAX working?
Reply 3 of 10, by Choum
You have the Following choice :
DSOAL = free wrapper that convert eax to openAL, full support of EAX 2.0, partial support for EAX 1, 3 and 4 (no support of EAX 5.0)
https://www.nexusmods.com/newvegas/mods/65094
Creative alchemy :
Full EAX support (1 to 5) : Free with all Creative card,
can also be buy it with Sound Blaster X-Fi MB3 (30$) if you want to use HD-Audio codec of your MB with full creative software suite.
http://software.store.creative.com/p/software … laster-x-fi-mb3
you can also see here : http://forums.thedarkmod.com/topic/18249-tuto … -any-soundcard/
If you want to buy a creative card :
I would buy : Sound blaster AE5 or one in the sound blaster Z serie.
Avoid X-fi titanium card has they have an unfix bug with hardware openAl in some game.
X-fi pci do not have the bug but they are old now (14Yo), but creative continue to create drivers for them (New drivers for Windows 1903 has been released)
Reply 4 of 10, by KainXVIII
Seems like my X-fi Xtreme Gamer edition also has openal bug, because it gives me constant BSOD with Quake 4 for example. This can be fixed by installing older drivers (XFI SupportPack 3.😎, but they are not working anymore with 1903 build. 😵 At least EAX game with Alchemy still working..
So my only option to play Quake 4 or Prey with EAX HD is to install Windows XP or what?
Reply 5 of 10, by svfn
Xtreme Gamer is PCI, if so, try this: https://www.reddit.com/r/SoundBlasterOfficial … dows_1903_beta/
SS7: K6-2/350 | FIC PA-2013 2.1 | 32MB PC-100 | 3dfx V3 2000 AGP | AWE64 CT4520 | Win98SE
On MobyGames
Reply 6 of 10, by svfn
Demo85 wrote:
I have, I gotta say i'm still a bit lost. Was thinking of paying the 30 bucks for Creative Labs emulation solution
i've tried X-Fi MB3/5 and personally don't recommend paying $30 for these, the software solution has unusual reverb in many games where an actual X-Fi card does not (with ALchemy). you'd be better buying a used X-Fi than these software solutions if you want to cover many games.
or you can just use DSOAL which works with onboard audio, also does have some bugs with games like reverb, and partial EAX support afaik.
if you don't care about EAX you can use OpenAL Soft for most games to get better HRTF, or use HeSuVi which simulates even CMSS-3D for virtual surround.
On MobyGames
Reply 7 of 10, by KainXVIII
Yes, i have BSOD with this drivers in Quake 4, shows this message "Driver IRQL not less or equal in ha20x2k.sys"
Reply 8 of 10, by cyclone3d
IRQL errors usually mean that there is something else wrong with your system. It is a common error when a system is overclocked and unstable.
Yamaha YMF7x4 Guide
Reply 9 of 10, by KainXVIII
Maybe, but with older X-fi drivers (which not working in 1903 build w10 anymore) i never had any BSODs..
Reply 10 of 10, by mdvhimself
sorry to resurrect the post, but it might help someone...so i was looking around in some other forums, and turns out, there are several solutions.
1. you get a creative card and install alchemy. you select the eax, exit the game, then open alchemy and allow the game. if you dont see it, you add it by directory.
2. if you dont have a creative card, you can hack the alchemy driver, gonna work with any other soundcard.
3. dsoal gonna emulate eax through good old openal
https://drive.google.com/drive/folders/17jlJ- … xF6?usp=sharing
