First post, by GEOCE
Hi, I have a problem with Windows 98, I have activated DMA on my hard drives and now the OS does not work.
Now, run on safemode Windows 98 but i don´t disable DMA, is hidden.
I need help, please. I wan´t install all SO.
Reply 1 of 7, by seleryba
Hi GEOCE. My idea is to remove all IDE controller devices in the Device Manager in safe mode. Then after reboot into the normal mode it may try to reset all the settings as OS will reinstall the drivers.
Aside of that, you can check the BIOS settings, there's a chance that some option is disabled and the PIO mode is forced by the settings there.
Reply 2 of 7, by texterted
Also, use 80 wire IDE cables if you can
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 3 of 7, by GEOCE
seleryba wrote on 2021-03-09, 00:02:
That has no DMA in the bios. xD
Only Mode Pio 1, 2, 3 or 4.
I use in auto.
Reply 5 of 7, by jesolo
GEOCE wrote on 2021-03-09, 12:21:
texterted wrote on 2021-03-09, 03:45:
Is the problem the cable? How can I know that?
Replace the cable with another 80 wire IDE cable - they normally have a grey, blue and black connector on each end. Also, you an easily see the wires inside the housing are much closely packed together (compared to a 40 wire cable).
Reply 6 of 7, by GEOCE
jesolo wrote on 2021-03-09, 12:30:
Thx 😀
I'm going to look for that.
