First post, by mashakos
Thought it might be useful to the ppl here who are fans of old windows games and niche emulators. Feedback appreciated.
https://github.com/mashakos/OmniScaler
Reply 4 of 10, by spiroyster
ZellSF wrote on 2021-04-20, 13:54:
He's said (elsewhere) that it isn't open source. You can only download the release.
Ok... where?
google gives me nothing for "mashakos" and "omniscaler" 🙁
EDIT: It's almost a googlewhack for me (I only get 3 results returned), which is something that has not happened to me in a long time...
Reply 5 of 10, by mashakos
spiroyster wrote on 2021-04-20, 14:58:
Ok... where?
github changed their UI recently, you should see a section to the right titled "Releases" on desktop. Which takes you to this page
https://github.com/mashakos/OmniScaler/releases
Reply 6 of 10, by mashakos
ZellSF wrote on 2021-04-20, 09:05:
I would like to see some D3D9 games scaled better (lanczos scaling for example), but that requires mouse input which I gather is rather complicated (dgVoodoo and GeDoSaTo often fail because of this).
mouse input required for pixel shader code? can you elaborate?
Reply 7 of 10, by spiroyster
mashakos wrote on 2021-04-20, 15:44:
Ok... where?
Brill thanks, didn't even realise that was clickable 😀
Reply 8 of 10, by mashakos
new version out.
https://github.com/mashakos/OmniScaler/releases/
Major updates:
  • Overhauled window clipping engine. Pixel offset edits in gamefs.ini are no longer required for 99% of situations.
  • Overhauled alt+tab, alt+enter logic.
  • Overhauled integer scaling and integer overscan scaling.
  • Custom mouse pointer. If a game does not include its own custom mouse pointer enable this feature:
    MousePointerEnable=1
    Custom mouse pointer is not compatible with overscan currently.
Reply 9 of 10, by schlomoe99
I just gave it a go, and now Westwood Monopoly starts in fullscreen! I can't yet access the top of the window after the intro videos, though,. Maybe I'll play with the pixel offset features...
Reply 10 of 10, by mashakos
schlomoe99 wrote on 2021-04-30, 02:01:
"Requires Windows 3.1 or later " hmm thats beyond the scope of my project !
