First post, by BEEN_Nath_58
MechWarrior 2 was one of the earliest 32-bit Windows game (Windows 9X era), released in 1995. The game also has a DOS version. With updates and changes to the Windows environment, the game becomes unplayable with newer versions of Windows. This thread aims to make the legend game playable on a native Windows environment. Currently, I aim to have the Pentium, Titanium and the Battlepack Editions in this thread; Battlepack having the most issues.
MechWarrior 2: 31st Century Combat Pentium Edition
The game uses a 16-bit InstallShield setup, which will fail to run on 64-bit Windows environments. On 32-bit versions of Windows, it should install just fine.
INSTALLATION
- Insert the CD in your drive.
- Install WineVDM v0.8.1 or greater on your machine.
- Set "START.EXE" to run with Windows 95 compatibility settings from the Properties menu.
- Running "START.EXE", click on the 'INSTALL' button to start installation.
- After installation finishes, copy the "DPLAY.DLL" from the "DIRECTX" folder of the CD to the game directory.
- Download and install the MechWarrior 2 v1.1 patch (This one seems to prevent a lot of corruptions and crashes).
If OTVDM is not supported (such as on Windows Vista), the only way to install the game is to copy all the files from the CD to a directory, and renaming "MECH2.EX_" to "MECH2.EXE", which is your executable. And then copying the "DPLAY.DLL" as explained earlier. But installing the patch would be troublesome, so search for an unpacked patch online or get the game installed and copied to the main PC from a VM.
RUNNING THE GAME
- After installation finishes, download DxWnd v2.05.85 or greater.
- Download the attachment for the Pentium Edition (mech2patch.zip).
- Install the .sdb file given in the attachment using the .bat file. Open DxWnd and use import the profile given attachment. Set your executable path through DxWnd.
MechWarrior 2: 31st Century Combat Titanium Edition
The game uses a 16-bit InstallShield setup, which will fail to run on 64-bit Windows environments and it also required a Windows 9X compatibility shim. On 32-bit versions of Windows, it should install just fine.
INSTALLATION
- Set "Setup.exe" to run with Windows 95 compatibility settings from the Properties menu.
- Running "Setup.exe", click on the 'INSTALL' button to start installation.
- During installation, choose the "HARDWARE ACCELERATION" option which installs the Titanium Edition of the game.
RUNNING THE GAME
- After installation finishes, download DxWnd v2.05.82 or greater.
- Rename "Mw2win.exe" to "Mw2tit.exe".
- Download the attachment for the Titanium Edition (mw2titpatching.zip).
- Install the .sdb file given in the attachment. Open DxWnd and use import the profile given attachment. Set your executable path through DxWnd.
If you are not having a bad day, then the game should start without a hitch. Double-click on the entry in DxWnd to launch the game.
