First post, by Presbytier
So, I am running Windows 11 and I can get Heretic II to run either using the 1.06 Enhancement Patch or the 1.07 one. Unfortunately on either one the game will crash if I try to load a save game. This was not as big of deal because it would allow you to load a level. However once I got to the second main area in the game you have to backtrack into other levels and if you do that the game crashes. I can't remember if I had a similar issue on Windows 10 because that was a long time ago now. So basically the game crashes when loading a save or backtracking into a prior area played.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
Reply 1 of 18, by Presbytier
Okay I figured this out. I was using the 3dfx GL driver to use nGlide for upscaling. Unfortunately, when using the 3dfx driver it would crash whenever trying to load a game. using the default opengl one does not.
Reply 2 of 18, by Presbytier
Since I was using Glide-GL and nGlide for upscaling does anyone know of any decent OpenGL wrappers that allow upscaling like nGlide or DgVoodoo?
Reply 3 of 18, by ZellSF
nGlide has a patch for this problem on the compatibility list:
https://www.zeus-software.com/downloads/nglide/compatibility
Presbytier wrote on 2022-05-15, 18:24:
DxWnd and Peixoto's patches should able to force a higher rendering resolution (which I assume is what you mean) for OpenGL games. I would recommend Peixoto's patches for Quake II engine games.
There's also the possibility of combining wrappers (QindieGL > dgVoodoo2), but I haven't run into a single game where that's actually helpful.
Reply 4 of 18, by Presbytier
ZellSF wrote on 2022-05-17, 22:21:
nGlide has a patch for this problem on the compatibility list: https://www.zeus-software.com/downloads/nglide/compatibility […]
Yeah i have tried nGlide's compatibility patch and it just doesn't work still crashes upon trying to load a save. So far only using stock openGl seems to work.
Reply 6 of 18, by Presbytier
ZellSF wrote on 2022-05-28, 10:58:
Did you get it working with Peixoto's patches? Should be relatively simple and work nicely at least until the fog issues that some GPU drivers have with OpenGL.
I never tried peixoto’s tbh, but the fog issue seems to on,y happen if you use the 1.07 fan patch. If you stick to 1.06 it doesn’t happen.
Reply 7 of 18, by DosFreak
Some other things to try:
I remember something about Heretic 2 and needing to set the sound to "default sound"? Try that.
Also try the game without any patch.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 8 of 18, by Presbytier
DosFreak wrote on 2022-05-29, 12:02:
I remember something about Heretic 2 and needing to see the sound to "default sound"? Try that.
So just tried with no patch and my game version off of the CD is 1.06a which is the enhancement pack version but like the one with the gore turned off. I wonder if this is why i have issues when applying other enhancement patches.
Reply 9 of 18, by Presbytier
looking further into this and I think I have some sort of standalone version of the game sold later as just a jewel case. it has a number on the back of the case T-624601 01 and there are other CD's on ebay without this. This number is imprinted on the disk itself and if you explore the disk there is a PDF of the game manual. So, I am wondering if this version of the game since it is 1.06a has issues with running, and being patched..
Reply 10 of 18, by Presbytier
So got a copy of a disc with 1.0 and like it still has the same problems so using 1.06a isn’t the issue. Here. The weird thing is now it crashes on loading a save no matter what.
Reply 12 of 18, by Presbytier
ZellSF wrote on 2022-05-31, 19:32:
I thought you said it worked in OpenGL mode? Play it in OpenGL mode. It's a OpenGL game, not a Glide game.
It stopped working in open GL mode and like you do know a lot of older games do run better with the miniGL driver and using nGlide.
Reply 13 of 18, by gerry
Presbytier wrote on 2022-05-15, 17:35:
if you had not worked it out then you would have had to beat the game in one sitting!
Reply 14 of 18, by ZellSF
Presbytier wrote on 2022-05-31, 21:32:
No, not really. Only old OpenGL games I can think of are all ID engine, and don't play better with Glide at all. At any rate, Heretic II definitely doesn't, there isn't even a widescreen patch for its Glide render.
Not really related to your problem though, if you're still getting crashes even with the OpenGL render, for anyone to be able to help you, you would need to produce save files and exact reproduction steps.
Reply 15 of 18, by Presbytier
ZellSF wrote on 2022-06-01, 09:15:
I’m not sure save files even matter because it’s literally every single one. The only reproduction step is to literally try to load one. The only thing you can do is warp directly to a map. This happens on 1.0 1.06 and 1.07. It was working at least in OpenGL mode, but for completely unrelated reasons I had to reinstall windows 11 now it crashes only on loading saves.
Reply 16 of 18, by DosFreak
You can try running dependency walker on it. Mabye it's loading an incompatible .dll. I remember issues with some games trying to load a3d .dll's and crashing.
Reply 17 of 18, by Presbytier
DosFreak wrote on 2022-06-01, 17:51:
Yeah I’ll give that a look especially since it’s doing it in a fresh windows install too.
Reply 18 of 18, by ZellSF
I'm thinking bad HID device, and since you made this topic earlier:
AIO Cooler Prevents Some Older Games From Launching
Maybe you disabled that on your old install and forgot on your new one?
I mean without more details we can't really help.
