Reply 882 of 3318, by sharangad
RaVeN-05 wrote on 2024-04-02, 12:13:
If you press alt+m or alt+x you should see fps, but game will go into timedemo mode, much faster
I can't. Keyboard interaction hasn't been implemented yet.
What kind of framerates do you get on your V2200/2100?
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 885 of 3318, by robertmo3
it looks random helmet generator when turning exists also on real hardware 😉
Reply 888 of 3318, by sharangad
Frame sync is also a big problem.
Rr. Exe, the rendition ready app terminates before everything renders. Bits of it render (first 1/3) with sync disabled. If not just a white screen., early frames. I think by studying this app I can get synchronisation working.
Reply 891 of 3318, by robertmo3
other "preserved" game features are:
- pulsating to square cars wheels in the distance,
- 2d textures "fireworks" (visible on a video of original hardware as dirty yellow horizontal lines)
thing i didn't noticed on video of original hardware is:
- gray road bank sometimes blinks
Reply 892 of 3318, by sharangad
Oh is the icr2 exe also called cart. Exe? It might be relevant if I need to feature mask rready special case handlers. I'm hoping it won't come to that.
Rendition. Cfg settings on a per app level will be migrating to the dosbox Cfg file, so I'll probably need to know all the exe names.
Reply 893 of 3318, by sharangad
robertmo3 wrote on 2024-04-02, 13:52:
SODA Offroad has similar issues. Might be a bug with rready.
Reply 897 of 3318, by 88mphTim
sharangad wrote on 2024-04-02, 13:57:
They re-released IndyCar Racing II as CART Racing. They don't seem very different and you can turn one game into the other by moving over the menu and cars.
In your video this morning the sound is playing normal speed. Video was definitely slower than it should be.
Reply 898 of 3318, by 88mphTim
I have both the Rendition indycar.exe and cart.exe if you need them.
