Reply 1180 of 1707, by sharangad
- Oldbie
Ignore this post!
Don't download and run this.
@robertmo3, could you try this build:
[HOLD off. Don't run this].
https://1drv.ms/u/s!As-dKk-N73dSmHk-dKxvBYHRfzcU?e=vniFrW
MD5: b32d7ee3fa7be3288bfad0407450172c
Keep dosbox in it's own folder.
The CPU load should be more manageable. I just hope it's not a pipe timeout or something.
[EDIT] RLauncher remembers the dosbox folder, so you should probably copy it into the dosbox folder.
I'm testing on an oct-core system. My dual core machines are Intel HD based and have issues running it. Both my spare GPUs are now dead so I can't tell if it's a GPU problem or a CPU one. One of them is a laptop. The game audio does playback with this build on the Intel machines. Graphically on Intel HD I get the splash screen and a static frame or splash and a black screen.
https://www.youtube.com/@sharangadayananda
