Reply 1180 of 1723, by sharangad
Ignore this post!
Don't download and run this.
@robertmo3, could you try this build:
[HOLD off. Don't run this].
https://1drv.ms/u/s!As-dKk-N73dSmHk-dKxvBYHRfzcU?e=vniFrW
MD5: b32d7ee3fa7be3288bfad0407450172c
Keep dosbox in it's own folder.
The CPU load should be more manageable. I just hope it's not a pipe timeout or something.
[EDIT] RLauncher remembers the dosbox folder, so you should probably copy it into the dosbox folder.
I'm testing on an oct-core system. My dual core machines are Intel HD based and have issues running it. Both my spare GPUs are now dead so I can't tell if it's a GPU problem or a CPU one. One of them is a laptop. The game audio does playback with this build on the Intel machines. Graphically on Intel HD I get the splash screen and a static frame or splash and a black screen.
https://www.youtube.com/@sharangadayananda
Reply 1182 of 1723, by sharangad
robertmo3 wrote on 2024-04-29, 08:51:
you should be able to disable as many cores as you want in bios
True, but I only power off or reboot at the end of day. Will test that in a bit.
That's a good test.
Reply 1183 of 1723, by sharangad
Your performance issues are down to the CPU being overloaded.
I'm making some other changes as well. It'll be a few days before the next build.
Reply 1184 of 1723, by robertmo3
yeah works only slightly slower on 2 cores.
1 core plays demo race with 4fps
the actual game plays fine, just the screen updates are delayed and at 0.0 fps 😉 (i was able to notice a second frame of the game after a very long time)
but i hear cars passing by at full speed and i can drive no problems 😉
Reply 1186 of 1723, by sharangad
robertmo3 wrote on 2024-04-29, 09:43:
yeah works only slightly slower on 2 cores. […]
Yup so pretty bad.
Reply 1187 of 1723, by sharangad
sharangad wrote on 2024-04-29, 09:49:
Yup so pretty bad.
Actually this is terrible.
Reply 1189 of 1723, by sharangad
robertmo3 wrote on 2024-04-29, 10:09:
why do you need so much cpu power?
my pc can run cyberpunk 2077
Threads busy waiting, checking for messages. It goes like this:
[Start]
If there's data process it.
got to Start
I did start out with wakeup notifications, but disabled them because of other problems. So they're going right back in.
Reply 1191 of 1723, by sharangad
sharangad wrote on 2024-04-29, 10:25:
Ok now for another round of testing.
It runs in dual core +hyperthreading mode on my Ryzen with stutters.
Once the thunderstorm stops I'll test quad core.
Reply 1192 of 1723, by sharangad
I think I've found the cause of pipe comms instability.
It appears to be cpu load related.
Reply 1193 of 1723, by sharangad
RReady's webserver will be down for maintenance on May 04 for 2 hours. It will be inaccessible, i. E. no game patches or demos can be downloaded either manually or via auto-download.
Apologies in advance for the 3 people using RReady.
Reply 1194 of 1723, by BEEN_Nath_58
sharangad wrote on 2024-04-29, 11:52:
Ironically we have storms and thunderstorms here too for about half a month now.
I wanted to ask if there's a minimum Intel HD Graphics limitation for RReady. I have a Win7 Ivy Bridge machine and I am looking forward to test it there sometime.
(asking since I will need to transfer games)
Reply 1195 of 1723, by sharangad
BEEN_Nath_58 wrote on 2024-04-29, 20:00:
@Been-nath58 El Nino/Indian Ocean Dipole is what's causing the storms according to the local weather people. The days are unbearably hot and it rains like crazy at night. The storms only started 4-5 days ago for Sri Lanka. I shouldn't complain, @Raven-05 is facing missiles.
[EDIT] The bare minimum is Sandy Bridge (OpenGL 3.3/GLSL 1.50 Compatibility Profile) in terms of APIs. Geforce 8800 might work as well. I no longer have one of these
to test.
My original target for RRedline was Sandy Bridge. *Some * games do run fine. Others have graphical defects with Sandy Bridge. Newer chips have fewer errors but some games (like SODA don't work very well. The menus don't work at all. GPL has issues as well. Front buffer effects like VH2's loading progress bars don't work on ay Intel HD CPU, barring adding a discrete GPU).
For Speedy3D, the CPU requirements will be higher, but I suspect most games should render correctly. I've got Dosbox-Rendition/RReady's CPU load down to 3 cores almost fully loaded. This is on a 4 GHz CPU so that's not as pleasant as it sounds. I'll do some more testing and tweaking. FIFO mode has lots of issues. So the Dosbox<-->DosClient comms have to be re-written to work better.
Reply 1196 of 1723, by sharangad
Ironically we have storms and thunderstorms here too for about half a month now. […]
Did you get Interstate '76 going or does it still silently RTD?
[EDIT] It doesn't run without DxWnd,. It won't work with any other DDraw wrappers.
Reply 1197 of 1723, by BEEN_Nath_58
sharangad wrote on 2024-04-29, 20:37:
I didn't check anymore in Win11. I will do on Win7
Reply 1198 of 1723, by sharangad
Another go:
Note this is a real alpha. The quality of the software may be iffy.
CPU load should be much much lower. Quad-core recommended. Bugs abound (Nascar 2/1999 might not run).
Dosbox-Rendition:
https://1drv.ms/u/s!As-dKk-N73dSmHvN7CeE6GxiZQmt?e=RmvG8z
MD5: 7b12a4338a57d1a7de6952fac21a5999
RReady-Speedy3D:
https://1drv.ms/u/s!As-dKk-N73dSmHrhVrhSMdO56sle?e=jxXoiM
MD5: 3d5a5983d3f6470ebd3d9689485d850d
Reply 1199 of 1723, by sharangad
CPU/framerate issues aren't because of Dosbox, it's all related to the implementation of Dosbox-Rendition and Dosclient.
