Reply 680 of 816, by Jules_nerd
Thanks for the summary, you put things in a rather more succinct readable form than I! 😉
Its a shame you cant quite fit more 18650 s in, I was rather hoping an off the shelf 2s2p pack would go in! I mentioned the charge controller supports 3 cells, with a circuit mod, but a 2s2p pack (with inbuilt protection & ideally charge leveling), if the case can be modded, should work OK with the existing charge controller etc.
I was looking at the GD542* datasheets last night trying to work out if it was easy to do a swap like you mentioned, you've saved me some work there, thanks! Did you have to do a specific ROM for the GD5428 with 512kKB?
Is the GD5426 also a drop in replacement?
The coin cell will help of course, like when the main battery is flat... however on the pocket386 the lack of one was not the main issue causing low of date/time /BIOS resets.- I know, I tried putting one on ... and Ive had a 'scope hooked up to that supply to the M6117, it was rock solid when powering on/off/plugging in external supplies. Others on the net also report a battery did not help.
This is why i tried a proper PSU monitor IC to generate the PWG signal. I'm not sure why this isnt working 100% on the BOOK386, I can only assume its the extra delay i put in my circuit using a BD5245-2M (though there is now BJT circuit, Q2&Q3, from the +5V to switch it in rather than just a diode, Im not sure what the designer has done this for), Im tempted to try this on the book rather than the max809 the designer has used, mind you the circuit diagrams do not say what threshold voltage max809 has been fitted, its possible its a bit low in an attempt to make it tolerate dips in the +5V??? Ill take a look at the markings when mine arrives
Did you spot if it as the PCB has R1 &C1 fitted ? as well as u14? the more I think about this the more likely I think it is that the designer was keeping his options open here...
There are a number of other small design improvements, the filter & series resistor on the 8051's ADC input monitoring the battery voltage now has series resistors, low pass filter (similar to my pocket386 mod) etc so it will give more constant readings, the higher battery voltage means he has had to include a potential divider, so the 8051s input is now better protected (this is what blew on my pocket386).
