First post, by javispedro1
Hello, for a couple of weekends I've been trying to create a new DOS mouse driver.
My intention is to do a "guest tools" for VirtualBox, at least on the level of the old Virtual PC 2004 tools. Mostly to learn something and have fun rather than anything serious.
I already also have a TSR for mouting Shared Folders (this one only VirtualBox).
However the mouse driver part also works in VMware (with integration too), and also kinda works on real hardware as a normal mouse driver.
I tried it at least on my T5710 with a real PS/2 mouse plugged in 😀 (no support for serial mice!)
It's not going to be as efficient as Cutemouse or as compatible as the real MSMOUSE, but it is written in C (OpenWatcom2) so I can try new fancy things.
Thought I am trying to keep the bloat under control -- so far it's around 9KB when loaded.
For example I have already stolen the idea from DOSBox-X of sending up/down arrow key presses when I move the scroll wheel.
Here's a video of using the wheel mouse in Edit/QBasic , recorded on VirtualBox, but you get the idea.
I also got the wheel mouse to work in real mode Windows 3.0,
however it does not work in 386 mode Windows due to an VKD.386 issue that I'll try to workaround some other weekend.
If you want to try, here's a zip file: vbados.zip. For VirtualBox/VMware users, vbados.flp (floppy image) will be more convenient.
It is open source, GPLv2+ -- Git URL here. I have written some documentation & pointers to the source code in the README. Builds anywhere where OpenWatcom2 runs -- including DOS itself.
Be warned that I've only tried with a couple programs, so it's likely that compatibility is very bad. I think I can split DOS programs in 3 categories regarding mouse:
  • Programs that use the mouse driver provided cursor/pointer: work OK, full host/guest mouse integration: most text mode programs, e.g. MS-DOS Edit, defrag, Cutemouse's mousetst 😀 , Adlib composer, DN/2 DOS navigatior (this one uses the wheel natively)
  • Programs that ignore the mouse driver provided cursor, and either use relative motion only or read the mouse themselves: should work, but WITHOUT mouse integration : WordPerfect6 with standard settings, Windows with standard driver, Theme Hospital, Monkey Island 1/2.
  • Programs that use the mouse driver provided cursor but still draw it on their own: work OK, partial host/guest mouse integration: Warcraft 2, surprisingly. WordPerfect6 when using the "Absolute/Tablet" mouse driver.
Obligatory (useless) screenshot:
Reply 1 of 38, by Jo22
Thank you very much! 😀👍
Reply 3 of 38, by javispedro1
FioGermi wrote on 2022-04-16, 22:58:
Hey, cool program! Out of curiosity: Is there anyway to add polling rate to this ala PS2RATE for Win9X? Makes the mouse feel smoother at the cost of some CPU (i presume?). Great for games 😀
Yeah it's trivial . I'm currently using 80Hz as default ( right here https://git.javispedro.com/cgit/vbados.git/tr … mousetsr.c#n989 ) but technically it can go as far as 200Hz
I'm attaching a build with default set to 6 aka 200Hz (only change).
Personally I found a significant difference between 40-60hz (windows 3.x seems to use 40Hz as default, and it feels sluggish after trying 60Hz), but no difference for anything >= 60Hz.
That's why I just left it at 80Hz.
No idea about the CPU usage, but I guess my mouse drawing routines are kinda slow -- I'm sure cutemouse is miles better in performance.
Should mention that it requires a 386 as a bare minimum due to use of 32-bit registers, but I am not sure what performance to expect on a 386 😀
Btw just looked : cutemouse uses 100hz as far as I can see. A comparison might be in order 😀
Also note: on a VM the sampling rate is basically the same as the host, I can't change that . was thinking real hardware 😀
Reply 4 of 38, by javispedro1
I actually got the PS/2 scroll wheel to work on real hw (my T5710) under Windows 3.11 in protected mode 😀
Would have made a video, but it would be boring...
I needed to patch VKD.386 , and I'm not sure if I can redistribute it (even though it actually comes as sample code in the Windows 3.1 DDK).
So I'm attaching a patch to the VKD sources:
wheelvkd_v1.patch
5.82 KiB
141 downloads
It also increases the sampling rate to 60Hz from 40Hz 😀
You'd also need the latest vbmouse.exe version which I just uploaded.
It is really a very stupid patch that will break any non-wheel aware mouse driver.
It simply makes VKD set the mouse to "Intellimouse"/4-byte packet mode unconditionally at startup, returns the wheel mouse device ID whenever asked, and removes all the packet segmentation code . Meaning overflow conditions may not be handled gracefully, dropping bytes randomly, so the DOS driver may need some synchronization code itself. However the code was not that functional to begin with, so not much of value is lost.
The 4-byte packets is what breaks most drivers, but if you use vbmouse as both DOS & Win driver, this shouldn't be a problem either.
Reply 5 of 38, by sam.reaves@gmail.com
Hello Javispedro1,
I just installed MSDOS on VirtualBox with so that I can run my old TangoPCB Series II+ on my Win10 machine. I installed your VBMOUSE and got it working (I only had to turn the integration off). However since the
highest resolution driver I can use is VESA1024 I find that the Mouse resolution is way too "speedy" and a small movement of the Mouse moves the cursor way too much. Is there any way to adjust this? When I am running Win7 in VirtualBox or Win10 natively the same mouse is perfectly fine.
Thank you so very much for creating this!
Sam
W3OHM
Reply 6 of 38, by javispedro1
sam.reaves@gmail.com wrote on 2022-10-08, 00:52:
Hum, if you have to turn the integration off, that kind of defeats the purpose of using vbmouse in the first place, since there will be little advantage over any other DOS mouse driver.
So... why did you have to turn it off? was it at least working inside MS edit? and then what is the behavior inside TangoPCB ?
For example it the mouse inside TangoPCB just "wiggles" a few pixels to the right but nowhere else whenever vbmouse+integration is enabled, then it means TangoPCB is reading the PS/2 port directly, ignoring the DOS mouse driver.
Or if it just moves at a different speed than the "host" mouse pointer then it likely means TangoPCB is reading the relative positions of the mouse and doing its own acceleration/sensitivity calculation from it.
And if it the mouse cursor just moves inside a smaller subrectangle of the screen and you cannot move outside of it, then it means the calculations for the current screen mode coordinates are wrong 😀 , which is likely in svga/vesa modes. Does it work in vga modes ?
If you are OK to go with integration disabled (i.e. you will be forced to capture/release the mouse from VirtualBox), then you could also try some other mouse driver like CuteMouse or MS Mouse. There should be no difference other than you lose the integration, for the programs that support it that is. So it would be nice to compare if they also have a speed issue "out of the box". MS Mouse at least also allows you to set the sensitivity (but I think the program may still override, IIRC).
It would be interesting to support integration in programs like this in vbmouse (assuming it doesn't work 😀 ), but since these programs are difficult to find...
If necessary I could put a user-controllable speed multiplier in vbmouse, but I would prefer to minimize the number of compatibility-related toggles.
Reply 7 of 38, by yyzkevin
This is great! I have been looking for something like this for a while. Only issue I have come across in my use case , when I am in Borland C++ 3.1 IDE, if I compile and run my program the machine will crash if vbmouse.exe is loaded.... even just a printf hello world will crash. Exiting the IDE and running the executable is fine, just using the RUN from inside the IDE in conjunction with the mouse driver. Strange.
www.yyzkevin.com
Reply 8 of 38, by javispedro1
Glad to hear!
yyzkevin wrote on 2022-12-10, 07:38:
I found this issue and think I have fixed it in the new 0.64.
The issue was that Borland is trying to save/restore the mouse state when you run a program from the IDE, and my driver was asking for too much memory. Borland seems to only allocate a 1K buffer for this no matter what, but I was using 1.5K, so I guess I was overwriting some of Borland's data.
With the fixed version I'm no longer preserving some of the VirtualBox data that didn't really need to be preserved, so that I only need 0.5K of the buffer provided by the IDE. This seems to fix the issue.
Reply 9 of 38, by MobyGamer
Great project! I would never have taken on "guest tools for DOS" but I'm happy you are 😀 I'm curious about your TSR for shared folders, where can I read more about that and how it works? Does it use the DOS redirection interfaces?
Reply 10 of 38, by yyzkevin
What a fast update! So it does not crash now which is amazing. What I do notice is, any time there is a dialog in the ide/turbovision, if the new dialog covers the current positon of the mouse cursor, if you move the mouse while the dialog is still open, it restores the character to the display from before the dialog opened.
javispedro1 wrote on 2022-12-10, 14:58:
Glad to hear! […]
Glad to hear!
www.yyzkevin.com
Reply 11 of 38, by javispedro1
MobyGamer wrote on 2022-12-10, 18:40:
There is an about page for the entire project with instructions -- https://git.javispedro.com/cgit/vbados.git/about/ -- I have written some details about the complicated parts, about not much details about the redirector part.
Yes, it is using the DOS redirection interfaces. When I started, I couldn't find any examples of either a mouse driver or redirector written in C, but it turns out there were some, like https://github.com/eduardocasino/vmsmount for VMware mounts (my TSR only does VirtualBox shared folders).
yyzkevin wrote on 2022-12-10, 22:05:
You are not using VirtualBox then? In VirtualBox the cursor is drawn by the host so this shouldn't happen. The fallback code which renders the mouse cursor in DOS itself is not that good. I'll take a look.
I found the issue, some incompatibility with the hide/show cursor API. It should be much better with 0.65.
Reply 14 of 38, by yyzkevin
Okay looks perfect so far in Borland C++ !
I am playing with this on a small web interface I have been working on to a legacy system. Previously I would capture the mouse to the canvas area so only the relative movements were sent to the vm in the cloud, but this had a lot of issues and of course pressing esc was not an option.
If you wanted to check it out, the login name is guest. It is not stable it is a work in progress, but this is using your vbmouse driver. In windows 3.1 (enhanced mode) I am using a different mouse driver I cannot remember the name this second.
https://ipx.network/terminal
www.yyzkevin.com
Reply 15 of 38, by javispedro1
yyzkevin wrote on 2022-12-11, 22:17:
Cool! Do you have a page/thread for this?
I was envisioning browser-based qemu.js emulators as yet another usecase, since they really benefit from mouse integration. I am guessing this is rather using vmware or qemu (with vmware integration), and remoting into it, right? Maybe there's a way to force capture/release the mouse for these games that still need to capture it, like Descent or Doom. Running "vbmouse integ off" temporarily disables the integration, and on VirtualBox/VMware this means the cursor goes back to being captured, but I don't know how to propagate this back to the browser so that it also captures the mouse...
Reply 16 of 38, by RetroTechChris
Just learned about this today (thank you, yyzkevin for the tip!). I see several other familiar faces in the thread here too 😀
Now I am wondering how difficult it would be to nominally do mouse integration for Win9X.. that would be awesome to have! I might have to look into it if someone isn't already working on it!
Reply 17 of 38, by javispedro1
RetroTechChris wrote on 2022-12-20, 06:10:
This already works as-is for 9x, you just have to install it manually , i.e. by loading VBMOUSE in autoexec.bat and then editing system.ini 's mouse.drv= line to point to vbmouse.drv.
Right now the only limitation is that there's no wheel support (like in all Windows 386 Enhanced Mode variants, albeit I have a working patch for 3.x).
Would that be for VirtualBox too?
I'm not sure of the benefits of a "native" 32-bit 9x driver. I have some unpublished work that I stopped because using the 16-bit driver seems to work as well.
Note that starting win98 you can already have mouse integration with VirtualBox via "standard" USB tablet and it works rather well, so this would be for non-USB win95 only...
And win95's 32-bit side has some bugs regarding absolute mouse integration, e.g. https://www.betaarchive.com/wiki/index.php?ti … _Archive/139292 , which kind of force you to override the 16-bit mouse.drv anyway .
From my side, I'm currently trying to fix the wheel situation with win3.x enhanced mode, which does require a 32-bit driver (same applies to win9x).
The problem with the wheel is that Windows helpfully "virtualizes" the PS/2 controller and mouse , so that multiple DOS VMs and Windows' mouse.drv itself can share control of the PS/2 mouse even if they are using different drivers. However, this virtualization has bugs ( http://www.os2museum.com/wp/jumpy-ps2-mouse-i … de-windows-3-x/ ) , and also prevents VMs from configuring the mouse so that it sends wheel information.
Result: no wheel, even if the underlying DOS/Windows drivers are capable of supporting it.
A couple messages ago, I posted a simple patch for VKD.386 that removes this behavior but this is far from ideal since I am not sure I can redistribute a patched VKD binary (and it breaks other DOS mouse drivers).
So what I'm trying to do instead is to write a new VXD that just hooks/overrides the broken parts of VKD, which I'm already finding a bit messy since I need to talk with the PS/2 hardware without VKD noticing at all, and either reinitialize the mouse on every VM switch or further virtualize it somehow so that each VM finds the mouse in the state it left it (wheel or not).
Also finding issues with Watcom's VxD support in the meanwhile ... https://github.com/open-watcom/open-watcom-v2/pull/1015
Anyway. I'm hoping the above experiences clear the way for more more VxDs, I specially look forward to implementing shared folders in win9x , but I'll probably also resurrect the 9x mouse integration then (so as to have only one driver calling into VirtualBox rather than two). I'll take me a lot of time though -- weekends development only.
Reply 18 of 38, by mbsystem
There remains a slight problem with vbmouse in VirtualBox, it is when calling some windows programs from a dos command prompt. At this point the cursor is positioned again at the top left of VirtualBox.
Reply 19 of 38, by yyzkevin
mbsystem wrote on 2022-12-22, 04:10:
Do you have some examples? and which windows 3.x or 95.
www.yyzkevin.com
