Reply 20 of 31, by Gmlb256
iraito wrote on 2021-09-17, 16:42:
Nope, still totally unstable at 4x, i'm starting to believe that a card meant for agp8x is just unstable on this motherboard.
I was also able to run a GF4 Ti on an AGP 2x slot from an ASUS motherboard without the need to set it to 1x. 😁
It wasn't a VIA chipset though and needed to use older drivers for the nVidia card instead of the lastest one.
Reply 21 of 31, by iraito
darry wrote on 2021-09-17, 18:24:
Can you try setting it to AGP 1x ? That's what it took to get a Radeon 9700 (8x) on my 440BX (2x) board stable .
It works at 2x, stable, deus ex thought ? it just doesn't behave.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 22 of 31, by iraito
Gmlb256 wrote on 2021-09-17, 18:35:
Can you test deus ex with that pc in d3d ?
Reply 23 of 31, by Gmlb256
iraito wrote on 2021-09-17, 18:39:
Sadly I don't have this game to help you with that. 🙁
Reply 24 of 31, by iraito
Gmlb256 wrote on 2021-09-17, 18:41:
No worries, i might end up creating a thread where i ask someone to test the game on a setup similar to mine, it's not a matter of where to play the game anymore, i wanna know why my PIII and geforce 4 TI can't deal with deus ex in D3d.
Reply 25 of 31, by Joseph_Joestar
iraito wrote on 2021-09-17, 19:08:
I have an AthlonXP rig with a GeForce4 Ti4200 if that works for you. I would need a save game and a screenshot of the issue in order to test out Deus Ex on that rig.
FYI, I ran it briefly when I (re)built that system last year, but I just used it to check the performance and test EAX.
Reply 26 of 31, by iraito
Joseph_Joestar wrote on 2021-09-17, 19:20:
https://www.youtube.com/watch?v=y-17-8EaVok Here at 1:43 the game freezes, it happens after 1 or 2 minutes even at the menu in d3d on win ME
Reply 27 of 31, by Joseph_Joestar
I'll test it out tomorrow and let you know how things went.
I don't have Windows ME though, just Win 98SE and Win 2000.
Reply 28 of 31, by iraito
Joseph_Joestar wrote on 2021-09-17, 19:30:
Thank you a lot! 98SE should be good, it's not that dissimilar from ME.
Reply 29 of 31, by Joseph_Joestar
iraito wrote on 2021-09-17, 19:36:
Ok, I just gave it a try. Loaded your save game and roamed around the level for 10 minutes or so. No freezes or any other issues. I then left the game running for about an hour, came back, and played for 5 more minutes. Everything was still fine.
This was with the Direct3D renderer using my GeForce4 Ti4200 on Windows 98SE + DirectX 7.0a with VIA 4-in-1 drivers v4.43 and Nvidia drivers 45.23. My Deus Ex copy is the retail GOTY version installed from the CD.
Reply 30 of 31, by iraito
Joseph_Joestar wrote on 2021-09-18, 09:21:
Then is the AGP, this system is simply unstable with this GPU in.
Reply 31 of 31, by iraito
Honestly at this point i'm almost willing to a buy a geforce 3 in the future and see if everything starts working correctly.
