Quarantine
First post, by just_let_me_use_this_once
I can't seem to get Quarantine to work. If I use command prompt on my $40 flea market PC, it runs too fast. If I run it on Dos Box on my PC, it's too slow. If I use Dos Box on my Mac and run Quarantine, it's also too slow. It appears to be too big for the 486 emulation but too small for the P2.
I thought I was only going to use this forum once.
Reply 2 of 6, by just_let_me_use_this_once
I know this is extremely old but I don't have the file "dosbox.conf" anywhere on my computer and since then I've been wanting to play Quarantine.
Reply 3 of 6, by MiniMax
Rank Moderator
Moderator
Which operating system, just_let_me.... ?
_________________
Reply 4 of 6, by leileilol
DosFreak wrote:
4. Change cycles=3000 to cycles=auto.
Auto will overspeed it as Quarantine has no throttling. 16000 works well.
Reply 5 of 6, by just_let_me_use_this_once
Mac OS X
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
You should start by making a DOSBox stuff folder inside your Documents folder ("/Users/your-login-name/Documents/DOSBox stuff").
Next, start DOSBox and ask it to create a configuration file in the DOSBox stuff folder:
Z:\>config -writeconf "/Users/your-login-name/Documents/DOSBox stuff/dosbox.conf"
Open dosbox.conf with the simplest editor you have on your Mac, and change the CPU cycles from the default 3000 to say 6123. Copy dosbox.conf to "/Users/your-login-name/dosbox.conf" and start DOSBox.
Does it show "Cpu Cycles: 6123" in the window title?
_________________
