First post, by AlessandroB
I have found it in an IBM 486DX4
https://drive.google.com/drive/folders/1-AxsS … Hig31ZV1QMD2Szr
tnks for the information
Reply 1 of 9, by waterbeesje
I've searched the main chip and it seems to me a programmable I/o controller. I'm not sure how to operate it, but others have been playing be around be with it:
https://bteworkshop.blogspot.com/2020/08/maki … d-with.html?m=1
Stuck at 10MHz...
Reply 2 of 9, by AlessandroB
It’s original IBM part i think. my suggest il to be a Gamport/joystick port.
Reply 3 of 9, by Robin4
I dont think it is a gameport / joystick port.. I think its a industrial card. Maybe an interface card.
Reply 4 of 9, by BitWrangler
It's basically an FPGA on it isn't it? So you could make it what you want, apple II emulation card or something 🤣
Edit: Though that might be close to original purpose, emulating a weirdass IBM terminal or speaking mainframe to whisper sweet nothings in an AS/400s ear or something.
Reply 5 of 9, by Horun
Yeah looks like some type of industrial interface card. On the 16bit ISA part it accesses Gnd, +5v, IRQ10, IRQ11 and IRQ12 if I read it correct. No 16bit Address lines...
So some simple 8bit w/16bit IRQ not-high frequency interface to some low speed equipment.....I do not think it was designed to connect to a terminal, too many low speed parts imho
Reply 6 of 9, by retardware
waterbeesje wrote on 2021-09-27, 13:41:
what a strange site... it asks me to install some strange "Green Blocker"... aww, tab closed instantly 😀
Reply 7 of 9, by soggi
retardware wrote on 2021-10-02, 03:41:
Tested it... It wasn't the mentioned website itself...but there is a delayed redirect to poweradblocker.com OR quantumadblocker.com. The solution is very simple: Just stop loading the page after you've clicked the link, this worked for me.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 8 of 9, by BitWrangler
Yah, Ublock Origin stops it but ABP doesn't.
Reply 9 of 9, by soggi
BitWrangler wrote on 2021-10-03, 19:11:
Yup, I'm using Adblock Latitude (forked from ABP) with NM27 and it doesn't stop that...NoScript is actually deactivated in this session (not comfortable for family members) - it would also block it, because it's most likely a JS redirect.
kind regards
soggi
