First post, by Kahenraz
This motherboard has a single IDE port and is able to recognize and boot to DOS. The problem I'm having is that while it can boot a disc, loaders which defer reading from the disk later after loading a driver like oakcdrom.sys fail because these drivers don't recognize an attached CD drive. This includes Windows 98 and ME setup.
I am booting to a SATA drive with DOS installed to test different CD device drivers but have been unable to find one that works.
I tried:
oakcdrom.sys
vide-cdd.sys
eltorito.sys
Does anyone know of a device driver that works with whatever this IDE controller is?
Reply 1 of 9, by Horun
Which exact Gigabyte board ? Some use "mixed chipset+additional controller chip",
As example the GA-P35-DS4 uses Intel P35 chipset for SATA but the single IDE port (and two more SATA) is off "GIGABYTE SATA2" chip which is a JMicron RAID controller chip.
GCDROM.SYS works with some of the JMicron, Intel and Nvidia SATA-IDE chips
Reply 2 of 9, by Stainlesscat
Horun wrote on 2021-09-27, 23:12:
The p35 and other northbridge chipsets don't have any sata controllers. Thats usually relegated to the southbridge chipset. In this instance the intel ich7 possesses the intel ultra ATA ide controller and sata controller. Which i recall should work with any regular cdrom or ide device drivers unless you are using an sata device.
Reply 3 of 9, by retardware
Also keep in mind that GCDROM.SYS only recognizes SATA ports 1-4.
CD/DVD drives that are connected at SATA port 5+ are not being recognized.
Reply 4 of 9, by Horun
Excuse me for not explaining in more detail. Yes the P35 is the Northbridge, it is matched with the ICH9 or ICH9R Southbridge and together is typically considered the "P35 Chipset".
Neither the ICH8 or ICH9 support IDE or Floppy, only SATA. So on some boards a separate chip or chips are used for Floppy and IDE if the board comes with them...
That is why I asked what exact board is it... 🤣
Reply 5 of 9, by Kahenraz
It's a Gigabyte GA-P35-DS3P. It even have a floppy connector.
Reply 6 of 9, by retardware
Try this driver from this download page.
It works just well when the normal PATA cdrom drivers don't find a drive 😀
Reply 7 of 9, by Horun
Kahenraz wrote on 2021-09-28, 00:52:
Thanks ! Yes it has a JMicron chip for the IDE and 2 SATA (GSATAii0 and GSATAii1), chip is labeled as "GigaByte SATA2" on the board. Here is the Headers from the Vista, Win2k, XP driver from Giga for GIGABYTE SATA2:
"Copyright 2005, JMicron Technology Corp." and "GIGABYTE GBB36X Controller" so should be a JMicron 363 or 368 based.
Try the GCDROM.SYS, the old website states: GCDROM.SYS supports all SATA Native IDE controller, such as Intel ICH6/ICH7/ICH8, Jmicron 363/368, NVidia CK804/MCP55/MCP51 etc."
More info: http://web.archive.org/web/20150407043219/htt … base/gcdrom.htm
It cannot hurt to try it.
retardware wrote on 2021-09-28, 01:08:
Wow you beat me by mere seconds ;p
Reply 8 of 9, by cyclone3d
Ok, looking at the block diagram in the user manual on page 8, the floppy port is coming off the IT8718 controller and the IDE is coming off the Gigabyte SATA2 controller. Depending on SATA port number that corresponds to, you may need a driver that supports past at least 6 ports. My guess is that the 2 SATA ports on the Gigabyte controller are 7 and 8 and the IDE would be port 9.
You may want to try setting the Gigabyte SATA/IDE controller to IDE in the BIOS. Not sure if that will help or not.
Also try setting the drive jumper to Master, Slave, and Cable Select. Sometimes a drive will only be detected if a certain setting is used.
And also try a regular 40-wire and an 80-wire IDE cable.
I'm not even sure any DOS driver will see that controller at all. They may only see the chipset ports.
Hopefully the GCDROM.SYS above works.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 9, by retardware
Horun wrote on 2021-09-28, 01:09:
cyclone3d wrote on 2021-09-28, 01:15:
I tried that driver on the DFI HD620-H81.
This board has 4 SATA ports, numbered in the BIOS as SATA 1+2 and 5+6.
When I tried the driver first, the drive was on port 5, didn't recognize the drive.
After re-plugging to port 2, it went smoothly.
BTW, it is not even a SATA drive 😀 It is an IDE drive, with the Sunplus Startech SATA-IDE converter.
This is necessary as I have quite some DOS games with audio on CD, and SATA drives don't have audio ports 🙁
And yes, I had to set IDE instead of AHCI mode in BIOS.
