First post, by red_avatar
The title pretty much says it all.
Basically, I want to make it a lot easier for me to play my old CD games by making copies using Alcohol 120%. I don't want to mess around with cracks and so on and for most 90's games, Alcohol 120% works just fine. I create the CD images on Windows 98 itself using Alcohol 120% 1.9.5. For some games, this doesn't work however and takes forever to do so I'd like to create images on my Windows 10 PC and even bought an Alcohol license but the images are not compatible with 1.9.5.
Does anyone have any idea if there's a version of Alcohol that works on Windows 10 that will create CD images that work on Windows 98? I don't need CD emulation support, just the ability to rip CD images.
Thank you for any feedback!
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 2 of 8, by red_avatar
DosFreak wrote on 2021-09-30, 14:42:
This version works on 95B and c,98,ME,NT4 (Haven't tried it on Windows 10), released 7-9-2005:
Alcohol120_retail_1_9_5_3105
I know, that's the one I'm using. The problem is it won't read images made with a recent Alcohol 120%. The Alcohol forums are no help and I can't find any info anywhere about what causes this incompatibility.
Retro game fanatic.
Reply 3 of 8, by TehGuy
I use the A120% on my XP machine that Phil posted here: https://www.philscomputerlab.com/daemon-tools … windows-98.html (probably works on 10 as well, wouldn't know since my main PC doesn't have an optical drive hence why I'm using my XP one)
Depending on the game and how it "doesn't work", you could be running into copy protection issues and, depending on what kind of protection it is, will have to tweak alcohol to account for it using the dropdown at the bottom left of the copy window (actually got my copies of Warcraft 3 + FT, as well as SimCity 3k working via images). Supposedly A120% can scan the disk and figure out what kind of protection it uses, but I've been using something else for that so IDK where that option is.
I use Daemon-tools from the same link to mount in 98, though, so no idea if it creates images that your version of A120% can work with. You'd figure things like Bin/Cue or ISO or MDF/MDS would just work. Either way, this might be the route to go when mounting on Win98 if you're going to move the disk ripping to a different machine (plus you'd probably be able to use the A120% tied to that license you just got)
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
Reply 4 of 8, by red_avatar
TehGuy wrote on 2021-09-30, 18:46:
I have Daemon Tools (Ultimate key) but the Windows 98 version of Daemon Tools is pretty worthless in what it can emulate. Alcohol 120% is far more powerful - so far only Star Trek The Fallen hasn't worked which is why I'd like to try with a more recent version on Windows 10. Daemon Tools was never as good as Alcohol even though it was more common - I mostly used Daemon Tools for mounting images in combination with cracks but my intent is to make CD images that are so good the copy protection doesn't know the difference.
Retro game fanatic.
Reply 5 of 8, by TehGuy
red_avatar wrote on 2021-09-30, 20:47:
let me run a few tests real quick
Reply 6 of 8, by TehGuy
Test 1: So the only type of image Win98 can't run from either DT or Alc is MDS/MDF, which sucks since the only things I have in that format are the games that had copy protection on 'em. ISO and BIN/CUE work fine, even when ripped using a newer version of 120%; it's just MDS/MDF files.
Test 2: Running the same versions between 98 and XP (1.9.5.3105) produces a mountable MDS/MDF pair on both OSes. Tested with Warcraft 3 with datatype set to SecuROM 4/5 as to rip the DRM with the disk, game acts just like it has physical media.
Conclusion: see if 1.9.5.3105 plays nice on windows 10, I cannot fully test this due to no optical drive on my machine
Reply 7 of 8, by red_avatar
TehGuy wrote on 2021-10-02, 01:50:
It definitely won't work because it's 32bit but thanks for the attempt! I may use my Windows XP machine to rip the images and hope 1.9.5 works properly on XP.
Retro game fanatic.
Reply 8 of 8, by henk717
Got an update to this situation, sorry if this is considered necro posting but this seemed the most fitting topic.
Turns out that while you can't install 1.9.5 on a modern Windows for ripping purposes it does work.
Here is the trick, with the old 1.9.5 I had no luck but they released a free retro gaming edition you can get from their site which is based on 1.9.5 but modern enough to not break for ripping.
Install this free program on your retro PC, now you already have a ripper there. If your retro PC's drive is good at ripping you are all set.
But what if like me its not and you have a good ripping drive elsewhere? Then copy the alcohol folder from your retro PC to your modern PC. Rename alcohol.exe to alcoholre.exe (or whatever you like) to bypass the compatibility lock. Run it as admin just to be sure, you will probably get an error it lacks its drivers, that only effects virtual drives.
With the program open rip the game you'd like. I tested it with a securom'd copy of rollercoaster tycoon 3 and the rip succesfully detected it as valid. And because its made with this 1.9.5 edition you can use that same edition to emulate it, and these seem to be daemon tools compatible to.
