First post, by dr.zeissler
Hi there,
normally I am using GLHexen/GLHeretic but on small machines that do not have decent or none OpenGL support I have to use something else. For Doom1/2 I use Doom95, but Doom95 does not work with Hexen/Heretic.
Old Heretic-Page: https://web.archive.org/web/20010822213908/ht … k/Heretic.shtml
Old Hexen-Page: https://web.archive.org/web/20010703105809/ht … kak/Hexen.shtml
My machine (K2/450 RageIIc and PCX1) has not enough power to get decent frame rates on fullscreen which means 640x480, so I use the "-width 400 -height 300" command, but this does only work in window-mode not in fullscreen. Using the switch "-fullscreen" always leads to 640x480. That's pretty bad because I would get decent frames on 400x300 on that machine. Playing in window-mode is not my cup of tea.
Do I make something wrong here? Do I have an alternative to get 400x300 ?
Doc
    winhexenb020.zip
    324.34 KiB
    64 downloads
    winhexenb010.zip
    320.89 KiB
    57 downloads
    winhereticb083b.zip
    258.44 KiB
    58 downloads
    winhereticb082.zip
    258.77 KiB
    60 downloads
    whtc05a9.zip
    415.71 KiB
    52 downloads
Reply 1 of 7, by DosFreak
Have you tried the below? All should work on 9x using software renderer:
Chocolate Heretic\Hexen 2.3.0
Crispy Doom 3.2
Doom Legacy 1.48.8
Rude 2.5.0c
ZDoom32 2.8.5c https://github.com/drfrag666/zdoom32
ZDoom-LE 2.8.1f https://github.com/drfrag666/ZDoom-LE
Think for such an old computer fastdoom may be a good option if/when it adds support for those games.
Make your games work offline
Reply 2 of 7, by weldum
i think that this machine is a little bit overkill for fast doom, why not use the standard dos versions on dos mode, or in windows they should work too
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 7, by Gmlb256
weldum wrote on 2021-10-03, 17:33:
FastDoom is also faster for that kind of machine than the vanilla executables. You can see the benchmarks that I did with a K6-2+/450 CPU here.
Although the original levels are indeed overkill though unless it brings support for SIGIL but that would increase the RAM requirements.
Reply 4 of 7, by weldum
i don't know, I've been playing sigil on my dos machine (p133, 32mb, 98se) with boom (doom with visplanes an other corrections) under dos and it's flawless, under windows is choppy
Reply 5 of 7, by Gmlb256
There are some parts in SIGIL where you will experience slowdown even in 320x200 on DOS, I witnessed that on a P233MMX prior upgrading.
Reply 6 of 7, by dr.zeissler
I should have written that the machine is strictly WIN95B/DX5. I'll try what you mentioned.
Reply 7 of 7, by hail-to-the-ryzen
Can test compatibility of this port with hexen and heretic:
https://github.com/drfrag666/ZDoom-CL/releases
I believe that uses directdraw version 3.
The PCX1 is probably a dx3-compatible video card.
