First post, by dr.zeissler
Hi there,
normally old retro-machines and fps-games means getting an opengl-source-port and use a voodoo-card to get decent framerates.
Now I consider checking the "old" or in other words "very early 3D accelerators". This leads to not having support on opengl,
the enigne not to support D3D and so on.
These are my thought's:
- on very early FPS games on old machines using the software-renderer leads to more performance than an early "de"-accelerator (in my case IIc/PCX1)
- sometimes the performance of the game is very different. Some are fast on 640x480 sVGA, some a relativly slow (so resizing the view helps)
- sometimes these games support strange resolutions e.g. 320x400 on VESA that I can't get the game into on my 15"TFT
- therefore usable resolutions like 400x300 and 512x384 or 640x400 are not available
I did a lot of testing and actually I prefer the more detailled and better colors on the software-renderer over the early 3D-accelerated stuff.
Games that are directly supported by their own api's like the PCX1-Version of Tomb1 are excellent, but if the game only supports Software or
D3D I am far better with the software renderer. (examples: TNP, Hellbender, Mageslayer)
What do you think about this?
Doc
Reply 1 of 9, by Jo22
Hi Doc! I share your point of view. 🙂
When I was playing Windows games in the 90s, I had no access to accelerators but faster CPUs.
In Windows, up to incl. Windows 98SE or DX 6.1, the software-renderer had been always an alternative.
A good 2D card with DDraw support was then assisting in blitting the rendered images asap to the screen..
It was starting with DX 7 that games demanded for a hardware renderer.
Much much later, with Windows 8 or so, the software renderer got upgraded again to allow things like Aero Glass without a powerful GPU.
Reply 2 of 9, by dr.zeissler
Thx Jo22, to me the lack of detail vs. the stutterfree smoothnes is a problem.
Lack of Detail:
- the early bilininear filtering is much worse than today, especially on small resolutions like 400x300/512x384. So I prefer software-rendering
- also lack of colours/contrast
Smoothness:
- that point goes to the 3d-acc. => here I am talking about the moving sky in doom etc. It stutters on software, but on 3D it's really smooth.
Performance:
- As I said, Hellbender on Software (K6-2/450) is MUCH! better as with Hardware-Acc. on RageIIc (Biliniar Filtering is always on and kill's performance; or PCX1 (freezes)
Doc
Reply 3 of 9, by Joseph_Joestar
Since you mentioned Tomb Raider, that game definitively looks much nicer with 3D acceleration.
Software rendering limits you to a 256 color palette which results in visible banding. Even the S3D accelerated version on the humble Virge will give you 16-bit colors, perspective correction and bilinear filtering. A few months ago I put up some screenshots for comparison here.
My retro builds
Reply 4 of 9, by dr.zeissler
Thx, the point is, if the game supports a special (early) api that my gfx-card supports, it's of course much better then using software-rendering.
Bilinear-filtering is a thing I am not 100% sure if I like it or not.
If the game textures are "optimized" for 3D and bilinear-filtering, than the lack of detail and colors are not so dramatric and therfore OK.
But if not, the lack of detail and colors are so big, that it looks like an ugly smearing of mud.
On the very early stuff in lowres, sharper and more colorfull textures are better to my eyes.
Doc
Reply 5 of 9, by dr.zeissler
The PCX1 has no bilinear filtering, but Tomb1(PVR) looks brilliant on it.
Reply 6 of 9, by BitWrangler
There's an accelerated ROTT?
Reply 7 of 9, by dr.zeissler
rott32 and winrott /winrottgl exist. But at least not usable for a machine-type I use (k6/2-450/Win95B/DX5)
Reply 8 of 9, by Gmlb256
Joseph_Joestar wrote on 2021-10-05, 09:00:
Bilinear filtering pretty much kills the performance on that card, disabling this will improve the situation. Few games has the option to disable it and I'm not fan of S3D though.
dr.zeissler wrote on 2021-10-05, 09:37:
Bilinear-filtering is a thing I am not 100% sure if I like it or not. If the game textures are "optimized" for 3D and bilinear- […]
I second this, in most cases bilinear filtering on very old games makes them look blurry due to the low resolution of textures at the time. That's why I prefer software renderer for these games despite being limited to 256 colors in many cases and requiring more CPU grunt for better performance at high resolutions.
Reply 9 of 9, by Joseph_Joestar
Gmlb256 wrote on 2021-10-06, 21:49:
On the original Virge, sure. But on the DX version, the performance impact is not as drastic, especially if you overclock it.
Reducing the resolution to 512x384 can help even further and it makes the S3D version of Tomb Raider somewhat playable (15-20 FPS on average). Not great, but not too bad either considering that software rendering in 640x480 runs at around 10-12 FPS on period correct machines (e.g. Pentium MMX 166).
My retro builds
