First post, by iraito
The game works as intended if i leave the hardware audio acceleration off but if i enable it i get a ton of stuttering in actions scenes.
If i lower the amount of audio channels from 16 to 7 the stuttering almost vanishes, so i guess it must be a performance issue either related to the hardware or software.
The PC is the WinME in my sign.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 1 of 11, by Namrok
I see that machine has a VIA chipset. Have you tried the VIA PCI Latency patch?
http://www.georgebreese.com/net/software/read … 0b21_readme.HTM
It fixed up my EAX crackling and stuttering issues like a champ on a VIA MVP3 board with an SBLive.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 2 of 11, by iraito
Namrok wrote on 2021-09-29, 13:53:
Never tried it, i will try that later, thank you!
Reply 4 of 11, by leileilol
My old workaround for this almost 21 years ago (!) was to alt-enter back and forth to clear it up.
Debian's fucked
Reply 5 of 11, by Namrok
iraito wrote on 2021-09-30, 06:40:
https://streamable.com/7nrahx
Seems to be working, the stuttering at the intro scene with the gun fight was atrocious before.
I take it the VIA PCI Latency patch worked then? Good to hear!
Reply 6 of 11, by iraito
Namrok wrote on 2021-09-30, 12:46:
Tested a lot of games, it didn't solve it, one games that seal the problem in the soundblaster is project IGI 2, if i choose any software audio driver i get no stutter but if i choose EAX of any kind then any weapon firing trigger some insane stuttering.
Reply 7 of 11, by Garrett W
Perhaps you should take a look whether you're using VXD or WDM drivers.
Reply 8 of 11, by Jasin Natael
What drivers are you using? WDM are garbage but more stable. VXD is the way to go if you can get them to work with the other hardware.
Also what version Live! card do you have? If you have the crappy OEM version it doesn't have hardware EAX support and will offload to the CPU which will kill performance.
Also the OEM versions won't usually work with the vanilla Creative drivers.
Reply 9 of 11, by iraito
My card is the SB0060, it's not OEM but i'm using Sound Blaster Retail Disc (SB0100 (5.1) & CT4780) for the drivers, which could be problematic.
Reply 11 of 11, by Jasin Natael
iraito wrote on 2021-10-07, 14:00:
Ok the VxD drivers solved the stuttering, damn, the WDM ones are insanely bad for the 5.1.
Yes they are complete trash. I don't know how they ever thought it was fine to release them in that state.
Glad that fixed the problem for you.
