My ghetto GPU storage
First post, by smullyoz
Had some time to kill today and came up with this.
Put a layer of anti static wrap on the bottom, wrapped a few wood pieces with anti static wrap and screwed them in the drawer, then slot some cards.
Any downsides to storing cards on their sides? So far ive usually just lay them down flat.
Reply 1 of 9, by matze79
Is this ESD Bubble Foil ? 😀
Reply 2 of 9, by retardware
smullyoz wrote on 2021-10-09, 21:34:
Put a layer of anti static wrap on the bottom, wrapped a few wood pieces with anti static wrap...
This is no conductive wrap, thus not anti static.
If the rose color isn't just added to deceive people, it only means that the bubble foil will not create big charges by itself.
... and screwed them in the drawer, then slot some cards.
The drawer... some unknown material wrapped in plastic laminate...
No, not at all, it is the recommended way to store this stuff.
I do this too. Here is my ghetto box of AGP and old PCI <=64MB:
file.php?mode=view&id=121292
This kind of ghetto storage is cheap, stackable and anti-static.
As the uncoated cardboard is conductive due to the ubiquitary humidity, no high voltages can build up, and charges get dissipated.
It is good style to grab the cards first by the slot brackets anyway, as this takes care of equalizing the potentials.
Reply 3 of 9, by smullyoz
Nice, is it just any old cardboard?
Also not sure about the bubble wrap but i know it said anti static on it. Do i run danger of static build up in the drawer at all?
Reply 4 of 9, by retardware
smullyoz wrote on 2021-10-09, 23:40:
Not "old" cardboard.
I took some then-new pieces of the same size (35x25x15cm) which I found convenient for my storage.
This was way cheaper and better suitable than any other box storage systems I knew of.
I am using these boxes for years now and am very satisfied.
The "separator inlets" I cut from thick cardboard, also taking care that there is no covering/coating/printing on them which could be detrimental to its antistatic properties.
Well, static electricity builds up when non-conductive surfaces are being separated/moved away.
So I'd suspect that this might also be the case in your drawer, every time you open/close it.
Reply 5 of 9, by Anders-
null
Måttfull och balanserad.
Reply 6 of 9, by smullyoz
retardware wrote on 2021-10-10, 00:01:
Not "old" cardboard. I took some then-new pieces of the same size (35x25x15cm) which I found convenient for my storage. This was […]
Interesting, well hopefully theyre ok in the drawer.
That brings up another question, are they better stored or better used as far as longevity? As we know parking your car and not using will destroy its tires for example as they're meant to be used. What about GPUs?
I mean i have a TI4200 that was basically sitting in a cardboard box for 10+ years, then i took it out put some new thermal paste and off it went, working great.
Reply 7 of 9, by Anders-
null
Reply 8 of 9, by imi
retardware wrote on 2021-10-09, 23:11:
^this
I mean sure the bubblewrap helps to protect, but the "anti-static" effect of the pink colored stuff is just that it doesn't produce static, it doesn't protect from static discharge, as long as you discharge yourself before handling them the chances of a static discharge are slim, but if you want to be absolutely sure you need to store them in sealed conductive bags ^^
but in all honesty it's probably fine, as you'll grab them by the cooler anyways ^^
