First post, by djsabreblade
Going through hell trying to install windows 98 on an old 2006 Toshiba P100 laptop. In short i've tried everything but nothing works. No matter what i seem to try setup blue screens right at the beginning of 'setting up drivers' some 'a fatal exception 0E has occured at 0028'. after i hit a key the computer freezes at setup with some green glitchy lines at the top of the screen. oddly enough i can boot into safe mode. so any possible solution helps..
Specs:
Intel Core Duo T2400 1.83GHz processor
17-inch glossy widescreen (1440 x 900)
nVidia 7300 Go graphics card
120GB 5400RPM SATA Hard Drive
1GB RAM
802.11 a/b/g Wireless via Intel 3945abg card
DVD dual layer burner
Duron 800mhz 256mb ram geforce2 mx Windows 98se
K8V-MX/S Sempron 2600+ 512mb Ram Radeon 9600XT 256mb Windows XP Pro Service Pack 2
djsabreblade.bandcamp.com
Reply 2 of 16, by dormcat
djsabreblade wrote on 2021-10-17, 07:14:
Intel Core Duo T2400 1.83GHz processor 17-inch glossy widescreen (1440 x 900) nVidia 7300 Go graphics card 120GB 5400RPM SATA Ha […]
1GB RAM
Those specs were not designed for Win98SE but WinXP:
Win98SE does not utilize multi-core, although you can run it on one of its cores
nVidia 7xxx series have no official driver for Win98SE (there are tweaks out there)
Win98SE has no native SATA support and needs a floppy loaded with SATA driver ready during installation
Win98SE natively supports up to 512 MB RAM; you need some tweaking to use larger RAM
The driver of Intel PRO/Wireless 3945ABG only supports WinXP and later OS
If you just want a stable machine that can be operated and maintained with ease, I suggest installing WinXP instead. Otherwise, if you want to challenge the possibility by modding and tweaking, wish you good luck then.
Reply 3 of 16, by djsabreblade
im feeling like people install 98 on unsupported hw all the time. why does it blue screen on setting up devices? is there anyway to bypass windows setup since i can use safe mode? i feel like if i could somehow get to the desktop in normal mode it might not blue screen and it could scan drivers then. btw it does indeed recognize the 1gb of ram in safe mode. so frustrating, just need to bypass setup or something. it may be the video card causing the problem to but how do i get past that? where do i get sata drivers?
Reply 4 of 16, by retardware
Basically all you need is the Loew Memory and SATA Patches.
Reply 5 of 16, by Jo22
Hi everyone! I'd rather use logic instead of religion here. 😉
The exception error hints to a driver (VXD) issue.
Fatal Exception 0E
This is a Page Fault interrupt. It typically occurs when Windows tries to access virtual memory on a demand-paged basis and the requested page of memory is missing or damaged, or when a paging protection rule is otherwise violated. When occurring in the 0028 memory range, it nearly always means that a device driver is implicated in the problem. Many of the Knowledge Base articles for these problems address specific hardware or settings issues.
FATAL EXCEPTION ERRORS
Probably it will not be easy to pinpoint the cause.
Good luck.
Zee
Source: : https://forums.techguy.org/threads/solved-win … th-this.628709/
https://retrocomputing.stackexchange.com/ques … g-windows-98-se
Maybe Windows Millennium is worth a try here? At least for testing purposes ? 😀
It is more compatible to newer hardware and uses much fewer VXDs (it mainly uses WDM drivers)..
Edit: Buggy CD-ROM drives might be also part of the issues.
I recommend running installation from hard disk.
If memory serves, do it like this:
Use the Win 98SE CD-ROM and boot DOS 7 with CD support.
Use FDISK and FORMAT C: /B
(FORMAT /B reserves space for DOS system files, but doesn't transfer them; some Win98 flavours do not install on a HDD with DOS installed)
Copy DRIVERS and WIN98 directories to HDD (use whatever OS you like)
Switch to C: and do CD WIN98 and run SETUP /NM
Reply 6 of 16, by djsabreblade
Thanks guys, i haven't given up...yet . i mean safe mode works, tried patching sata makes no difference. will try mem patch again later, and as a last resort ME although i'd much rather have the nostalgic 98. also made a youtube video here if it helps : https://www.youtube.com/watch?v=RCKq-maxYpE
Reply 7 of 16, by Joakim
I would start by checking that fans are spinning and reseat rams. If it doesn't help I would install windows xp and run some benchmarks. Those issues look like over clocking or bad ram to me rather than windows 98 failing.
+1 retro points on the camcorder btw
Reply 8 of 16, by Stainlesscat
Try installing windows 98 with the command switch setup /pi at the dos prompt with the windows setup utility. Later computers with their implementation of ACPI bios causes blue screens on windows 98.
Reply 9 of 16, by djsabreblade
tried exactly ''setup /pi /nm'' install from hard drive
it worked!!!!!!!!!
CREDITS TO STAINLESS CAT AND JO22. WOW. THANKS TO ALL BTW. 😀
Reply 10 of 16, by djsabreblade
So now I just have to fight with video drivers. It installs the modded drivers fine and even detects the card as 7300 Go but as soon as windows loads I get a black screen. any tips?
Reply 11 of 16, by macroexp
djsabreblade wrote on 2021-10-17, 19:44:
Just a hunch: Try putting a monitor on the video out (vga?) and see if maybe it’s mistakenly using the wrong display or using a mode unsupported by the laptop panel. Or just try the keyboard hot key for monitor internal/external and see if you get any activity.
Reply 12 of 16, by janih
macroexp wrote on 2021-10-18, 02:13:
This hunch is a good one. I have a similar specced laptop (Asus A6JC: Core Duo T2300, Geforce go 7300) that I've been dual booting w98se and winxp. The output goes sometimes to external. I've noticed that if I just reboot the machine the main display works again. I've found the modded nvidia drivers to be a bit flaky in windows 98: screen goes black for a few seconds sometimes etc., so I've been just using windows xp instead. Has anyone had better experience with Geforce 7 in windows 98?
Reply 13 of 16, by Joakim
I read somewhere here that you can flash the VGA bios to run gf 6 drivers on a gf7 card but it doesn't work that good if it has over 256 vram. If this works at all or if it is even relevant for mobile cards, I dunno, never tried it myself.
Reply 14 of 16, by djsabreblade
I found a good solution. Screen will stop going black if you put hardware acceleration on 'basic' which is fine for everything except videos and games. Also switching to 'full' acceleration for gaming will work (usually) by restarting the laptop twice. I'm using directX 7.0a and it works.
Also was wondering what the cheapest audio solution would be since I can't figure out how to install the drivers which aren't compatible. Not sure if generic audio drivers exist?
Reply 15 of 16, by janih
djsabreblade wrote on 2021-10-18, 20:33:
I found this guide for Intel HDA, but haven't tried it myself: https://retrosystemsrevival.blogspot.com/2019 … hda-driver.html
Reply 16 of 16, by djsabreblade
The Intel HDA instructions are confusing. Are there any cheap-ish usb audio interfaces that work with 98?
