Hi everyone! I'd rather use logic instead of religion here. 😉
The exception error hints to a driver (VXD) issue.
Fatal Exception 0E
This is a Page Fault interrupt. It typically occurs when Windows tries to access virtual memory on a demand-paged basis and the requested page of memory is missing or damaged, or when a paging protection rule is otherwise violated. When occurring in the 0028 memory range, it nearly always means that a device driver is implicated in the problem. Many of the Knowledge Base articles for these problems address specific hardware or settings issues.
FATAL EXCEPTION ERRORS
Probably it will not be easy to pinpoint the cause.
Good luck.
Zee
Source: : https://forums.techguy.org/threads/solved-win … th-this.628709/
https://retrocomputing.stackexchange.com/ques … g-windows-98-se
Maybe Windows Millennium is worth a try here? At least for testing purposes ? 😀
It is more compatible to newer hardware and uses much fewer VXDs (it mainly uses WDM drivers)..
Edit: Buggy CD-ROM drives might be also part of the issues.
I recommend running installation from hard disk.
If memory serves, do it like this:
Use the Win 98SE CD-ROM and boot DOS 7 with CD support.
Use FDISK and FORMAT C: /B
(FORMAT /B reserves space for DOS system files, but doesn't transfer them; some Win98 flavours do not install on a HDD with DOS installed)
Copy DRIVERS and WIN98 directories to HDD (use whatever OS you like)
Switch to C: and do CD WIN98 and run SETUP /NM
