First post, by beach
It won't work. In DOSbox .65 and ykhwong's .66, I get some music on a blank screen followed by a brown bar at the top. After hitting escape, the game loads with no errors, but nothing happens. In the new .70 version, the game gets to the menu, but then either blackscreens or doesn't respond when I hit menu buttons.
The windows version (which I'm leery of using) asks me to insert the BC3K cdrom in drive C.
System:
XP pro SP2
GeForce 7800 GTX
P4 3.2GHz
Config (from gulikoza's .70):
[sdl]
fullscreen=true
fulldouble=false
fullresolution=original
windowresolution=original
output=direct3d
autolock=true
sensitivity=400
waitonerror=true
priority=highest,normal
mapperfile=mapper.txt
pixelshader=bilinear.fx
usescancodes=false
[dosbox]
language=
machine=vga
captures=capture
memsize=64
[render]
frameskip=0
aspect=false
scaler=none
[cpu]
core=dynamic
cycles=auto
cycleup=500
cycledown=20
[vga]
svgachipset=s3
videoram=4096
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=win32
mt32rate=22050
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=false
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=false
pcrate=22050
tandy=auto
tandyrate=22050
disney=false
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[autoexec]
mount C c:\
mount E e:\ -t cdrom -usecd 0 -ioctl
mount F f:\ -t cdrom -usecd 0 -ioctl
c:
cd bc3
Thanks,
beach
