Reply 20 of 24, by cyclone3d
- l33t++
Zup wrote on 2021-10-19, 09:59:That reminds me two (almost) unrelated questions: - My wife computer has a LiteOn SHM-165S6S DVD drive that does not want to ope […]
mockingbird wrote on 2021-10-18, 14:36:If you're a more practical person, and you want something inexpensive that will cover all your bases, then you want either the LG GSA-H10x or GSA-H12x, both models being Renesas-based (as opposed to the lousy Panasonic varieties).
These drives don't need their capacitors changed, all they need is a belt cleaning or else the tray won't open.
- My wife computer has a LiteOn SHM-165S6S DVD drive that does not want to open. The symptons are that when you push the open button or try to eject through explorer, it makes an "going to open"/"i better close that" noise (clac-clac) but the tray barely moves. If I force open it, it closes as intended (and sometimes it's able to reopen). May it be related to that belt (I thought a tray position sensor could be involved)?
- I've been trying to make ISOs from some spaniard edited games that had a "ring" protection. That is, a bunch (usually more than 5000) non-existant sectors that appears like a ring on the disc. Obviously, it takes ages to make an ISO image (more than 10 hours)... a better drive could mean faster image extraction?
If making a regular ISO, can't you just tell the software to not retry on read errors? What software are you using to make the ISOs?
