Reply 120 of 153, by ruthan
@tyukok You can share some disk benchmarks here:
Reliable Windows 98 storage benchmark
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 121 of 153, by tyukok
tyukok wrote on 2020-03-07, 16:14:
there was no DMA checkbox. And when I switched over to onboard SATA controller, there was no checkbox either
I should've read README.TXT better:
AHCI, by design, uses DMA. DMA is always enabled and the DMA Option will not be visible in the Device Manager Settings.
Reply 122 of 153, by RayeR
I just found a new review of MSI MB with PCI & ISA slots for LGA1151 platform (H110 chipset)
https://www.tomshardware.com/news/spectras-ne … -1992-pci-slots
It seem's nothing surprising, just another overpriced industrial MB. I wonder if ISA DMA would work there. I was not able to find that ISA bridge chip it use, some hi-res photo would help to figure out...
Reply 123 of 153, by Tiido
A thread was made of this board earlier today. I do wonder what bridge chip it uses, so it could be determined if there's ISA DMA or not.
Reply 124 of 153, by ruthan
Mentioned thread:
MS-98L9 V2.0 , a new 1151MB with an ISA slot
These is some datasheet:
https://b2b.rosch-computer.de/shop/file.php?a … plication%2Fpdf
Where is this - 1 x ISA Slot (Windows 7 32-bit Supported Only), because machine officialy supports only Win7 to Win10, its probably about it.. not about that it needs special driver, but i could be wrong.. Win10 probablyditched ISA same as AGP.. i never installed on ISA MB anything newer than Win7, maybe someone did.
Reply 125 of 153, by RayeR
Where is the dedicated thread?
AFAIK Win10 dropped support of ISA subsystem from the kernel so ISA card may not work there but it could work in DOS.
The datasheet has better photo, from this I can read:
IT8892E - PCIe to PCI Bridge
F81866AD - LPC based superIO with 6x UART, LPT, FDC...
F85226AD - https://www.alldatasheet.com/datasheet-pdf/pd … TEK/F85226.html Yeah! the LPC2ISA bridge, not PCI2ISA as on 99% of other MBs. So there's a chance ISA sound would work there. So anyone has enough courage to waste his money and test it? 😀 I already wasted >300$ for Commell P4LA years ago (that turned out to have wrong bridge without ISA DMA...)
Reply 126 of 153, by Tiido
Ok, nice, same bridge as my C2D board. This is exciting as the bridge definitely supports ISA DMA, as long as LDRQ is connected ~
My pockets are empty though, but if I am gonna upgrade, that's a board I would want to get 🤣.
Reply 127 of 153, by cyclone3d
I really don't think that board will support ISA DMA but I could be wrong. I looked through the manual the other day and the BIOS doesn't seem to have any settings for reserving IRQ or DMA or anything else having to do with legacy support.
Wouldn't the motherboard chipset also have to have support for ISA DMA through the bridge chip for it to be supported?
What chipset does your C2D motherboard have?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 128 of 153, by Tiido
LPC bus has everything necessary, what does matter is IO ports configuration and a custom utility will be needed for that. DMAs aren't used by anything on the board though IRQ assignments may be on the arbitrary side by the BIOS but that can still be fixed by reprogramming the chipset.
EDIT: actually you were onto something, I got the H110 datasheet and LPC bus lacks the LDRQ signal, thus DMA will not be possible even if the bridge supports it.
My C2D board is G41+ICH7 based, RUBY-9719VG2AR
Reply 129 of 153, by RayeR
Thanks for your attention. Damn intel! I tracked chipset datasheets and the LDRQ was removed in 1xx series. The latest with LDRQ are H/P9x and X99. Do you have an idea how to overcome this issue with your FPGA/CPLD solution? Could they use some proprietary logic for this? I very doubt.. 🙁
Reply 130 of 153, by Tiido
Lack of LDRQ means that DMA controller should be finally deleted from the chipset, which means it should be possible to create your own over PCI or PCI-E and no longer need LPC for anything except for SERIRQ signal. FPGA will be necessary though, CPLD will be too small for such a stunt. PCI-E puts big latency on IO operations and the result may be fairly wonky, it is all untreaded territory and not something I'll venture into anytime soon.
EDIT: I have been looking at how IRQs work for PCI-E and you cannot actually target any specific IRQ with it. There's two mechanisms : the legacy INTA/B/C/D mechanism of normal PCI and "message signaled interrupts" and those can only be used with APIC inside the CPU.
PCI interrupts have arbitrary allocation by whatever BIOS sets things up and there's only 4 of them that are shared by other cards.
Message interrupts don't involve the legacy interrupt controller at all. I don't know if it is possible to program the PIC to trigger an interrupt in software, if so things would be possible with a software layer that sets up APIC which handlers then program PIC to generate an interrupt which is seen and handled by whatever DOS game etc. I'm not sure if the latency is unworkable or not.
Reply 131 of 153, by OMORES
So far, I had a good experience with PCI-E to PCI in Windows. It works. I installed different video, network and sound cards in 3.11*, NT3.51/4 & Win 95/98 on X470 motherboard with 2 PCI slots ( Asmedia bridge chip). As a bonus, this motherboard has some basic settings in BIOS for the PCI slots. You don't get this with an PCI-E to PCI adapter.
Letting aside sound cards... in DOS, I was surprised how easily you can install a NDIS DOS driver for an Intel Gigabit PCI-E gigabit card in Windows 3.11. (or 95/98) These DOS drivers are even up to date.
Now I want to buy an expansion box PCI-E to 4 x PCI. First I saw this model from Startech. But I guess this EX-1010 model (by Exsys) is 100% the same but with a 50% discount...
Did anyone tried one of these boxes? They are not cheap considering that with 20$ you can buy 1PCI-E to 2 x PCI. For 215.79 € you exchange one PCI-E 1x slot for 4 classic PCI, you get an elegant metal case and a solid cable connection. (I would never use one of those cheap PCI-E to PCI adapters with ribbon cables... )
My latest video: NT 4.0 running from M.2 PCI-E AHCI SSD.
Reply 132 of 153, by Hanamichi
Hi Omores,
I have one of these but never tested it for retro goodness, only for HTPC soundcard use.
For me the great feature is that an external PSU can easily be used, potentially a linear one for clean audio.
It worked in X58, Z170 motherboards, I will try it in a W98 build when I can.
Reply 133 of 153, by rasz_pl
sooo this popped up https://blog.adafruit.com/2023/03/22/adding-a … puting-rasteri/
https://www.youtube.com/watch?v=IXr-VEpQ1lg "Adding an ISA Slot to a Modern Motherboard!"
terrible ungooglable name, mentions DMA needs LDRQ
"If you want DMA (most DOS games) it'll need to be a TPM port with an LDRQ# signal."
Reply 134 of 153, by tyrells
rasz_pl wrote on 2023-03-23, 07:35:
sooo this popped up https://blog.adafruit.com/2023/03/22/adding-a … puting-rasteri/ https://www.youtube.com/watch?v=IXr-VEpQ1lg […]
Here is the link to the Vogons thread: dISAppointment - LPC to ISA adapter - ISA on modern motherboards
Reply 135 of 153, by rasz_pl
I dont follow "announcement" subforum, but just found same link while trying to google that terrible ungoogleable name 😀
Reply 136 of 153, by RayeR
BTW yet another MB (probably with LPC2ISA bridge), claiming ISA DMA support. But still only old C2D LGA775 platform 🙁
https://interloper.com/products/details.php?p … =111151&cat=317
Reply 137 of 153, by LSS10999
RayeR wrote on 2023-03-23, 17:14:
I took a look at the pic and it seems the larger chip near the ISA slot appear to be Winbond's, and it seems there is a smaller chip nearby, which kind of matches the use case of Winbond's PCI-ISA, W83628F & W83629D. For a PCI-ISA scenario, both chips are needed to implement everything necessary.
However, I couldn't remember if Winbond's LPC-ISA, W83626, also required a similar companion chip. I looked at some documents I could find and it seems the LPC-ISA chip could work on its own.
Still, the thumbnail is too small to clearly see everything so I can't be entirely sure what the chips near the ISA slot really are. If it turns out to be PCI-ISA then there's no way DMA would work.
Reply 139 of 153, by RayeR
Winbond LPC2ISA should work alone. It only requires to wire LDRQ signal to it.
