How do I apply thermal paste to this cpu?
First post, by JustRob
Got this in a box of parts... I thought cpus usually had a bigger metal surface on top, but this one only has this small square. Do I put thermal paste on the board itself too, or just that small bit in the center?
Reply 1 of 21, by zapbuzz
just the small bit in the center 😀
Besides even if you did cover the whole chip the green area wouldn't come into contact with the heatsink.
(Igot 2 of those chips and my advice is applied to them running nice and cool)
Reply 2 of 21, by JustRob
Huh. Crazy that it can transfer heat from such a small surface area. But oh well, if it works it works.
Reply 3 of 21, by Jasin Natael
JustRob wrote on 2021-11-09, 16:13:
The large metal square you are referring to is called the Integrated Heat Spreader, or IHS. It is simply a flat metal piece that is covering the substrate (green) area and the actual CPU die (the small square).
There is a thermal interface material in-between the die and the IHS, sometimes solder sometimes a specialized thermal compound.
Regardless nearly ALL CPU's will look like the one you have pictured once the IHS is removed. This is called de-lidding. Some enthusiasts will do this in order to cool to bare die for overclocking.
Reply 4 of 21, by dormcat
JustRob, this is a typical packaging of Socket 370 Coppermine Pentium 3 / Celeron and Socket 462 Athlon / Athlon XP / Duron / Sempron processors. Here's another example:
The attachment Athlon_1200C.jpg is no longer available
Exposing the die can increase the rate of heat dissipation (by contacting the die directly to a heatsink) and reduce the amount of thermal paste needed, but can also increase the risk of chipping the die when installing a heatsink. AMD processors have soft pads at four corners (see the photo above) to reduce this risk but Intel processors have no such device, so be careful while lowering your heatsink onto that CPU.
Reply 5 of 21, by RaiderOfLostVoodoo
dormcat wrote on 2021-11-09, 18:09:
Yupp.
Got this CPU last week:
The attachment Die.png is no longer available
Have a look at the bottom left corner.
No post, no beep.
But in that case I didn't care. It's a crap CPU anyway and came with a mainboard. I just wanted the mainboard. Got a small refund for the broken CPU, which is nice, because I don't have to sell it now.
Same thing happened to me in the past with old Socket 462 Athlons. Thermalpaste back in the day used to become super dry and hard. I did ruin 2 old Athlons when I removed the cooler.
Coppermines (like the one in your picture) are a bit more durable.
Some people these days even remove the heatspreader from modern CPUs, so they can put the cooler directly on the die.
It's called delidding. There are plenty of tutorials on Youtube.
Reply 6 of 21, by zapbuzz
wow what a twist this thread is becoming de-lidding and getting a part refund for damaging stuff 🤣
seriusly its intel and all i see is a contaminated lid. The lids are basically impossible to remove from a socket 370 coppermine.
If it were an AMD it would be different.
Looks exactly like my ones they have lids like that too.
leave the lids alone geez 😀
Reply 7 of 21, by RaiderOfLostVoodoo
zapbuzz wrote on 2021-11-09, 18:28:
I didn't damage it.
The seller damaged it, when he took off the cooler.
Just a reminder to be extremely careful when handling Socket 370/462 CPUs.
Reply 8 of 21, by Doornkaat
wow what a twist this thread is becoming de-lidding and getting a part refund for damaging stuff lol seriusly its intel and all […]
If by 'lid' you mean the heatspreader SL52R comes without one.
Reply 9 of 21, by Disruptor
JustRob wrote on 2021-11-09, 16:21:
It's true. The energy density can be compared to active fuel rods in a fission reactor. It's about 100 W/cm².
A hotplate of an electric stove? Peanuts with its 10 W/cm²!
This is why thermal paste is so important. Between the CPU die and the cooler there has to be not one bubble of air.
However, do not apply too much of the thermal paste. Pea size should be enough.
Reply 10 of 21, by retardware
And before applying the new thermal paste, use Q-tips dipped in alcohol to thoroughly remove residues of the old hard paste.
I usually cut a credit card (or similar) to evenly spread the new paste before attaching the heat sink.
And I am always afraid of twisting the heat sink, breaking off a corner of the die. This makes so important to alternately turn the screws of the cooler.
Reply 11 of 21, by Sphere478
Not enough thanks is given to the people in this group that take the time to explain things to people trying to learn. Very good job with the replies in this thread guys 😀
put some kinda shim on the corners to keep the heatsink from putting edge pressure on the die during removal and installation. Athalons used them a lot.
https://www.google.com/search?q=athalon+shim& … 3US913&hl=en-US
Just a small drop on the die is all that’s needed of thermal compound. Don’t over shimm though and make a gap between the heat sink and die.
Sphere's PCB projects.
Reply 12 of 21, by imi
RaiderOfLostVoodoo wrote on 2021-11-09, 18:20:
Yupp. Got this CPU last week: Die.png Have a look at the bottom left corner. No post, no beep. […]
Yupp.
No post, no beep.
a chipped die like that doesn't necessarily mean the end of a CPU as long as it doesn't go too far, I remember my old Athlon C had a far larger chunk than that broken off the edge and it still worked just fine.
Reply 13 of 21, by Repo Man11
I remember my SLK-900A came with a set of bumpers to put on the CPU because the base of the heatsink was too narrow for the stock AMD ones. It was very, very easy to chip the die if you mounted that heatsink without them.
Reply 14 of 21, by zapbuzz
Doornkaat wrote on 2021-11-09, 20:59:
Thanks I thought that was the case 😀
Reply 15 of 21, by zapbuzz
RaiderOfLostVoodoo wrote on 2021-11-09, 18:57:
I didn't damage it. The seller damaged it, when he took off the cooler. Just a reminder to be extremely careful when handling So […]
I didn't damage it.
Thankyou faith restored 😀
Reply 16 of 21, by RaiderOfLostVoodoo
Yeah, exposed die, just like with Socket A Athlons.
Difference is just, that the glue (or whatever it is) around the die reachers further up and protects the corners/edges. That seems to help a lot, if I compare used Coppermines with used Athlons on Ebay. Most used Athlons have at least some minor damages to the die.
imi wrote on 2021-11-10, 02:52:
Indeed, there is a thin protective layer on the die. Depends on how deep the damage reaches.
Reply 17 of 21, by Tetrium
Yupp.
No post, no beep.
Some years ago I was contemplating on whether it would be possible to disable part of the cache and make it work again if the chipped part of the CPU just happens to be that damaged cache.
Iirc I do remember that some of the bridges controlled the size of the CPU cache (with 256kb having a way to disable either half or 3/4th of the cache).
Seems like a not very useful hack for now (if it works), but perhaps for the future just ftr.
My retro rigs (old topic)
Report spammers here!
Reply 18 of 21, by Tetrium
What I always do is to (after cleaning both the heatsink and the CPU area that is to receive the TIM) apply a small bit of TIM on the center of the die (like half a grain of rice or something), then hover the heatsink slightly above the CPU socket and put one clip in. Then place the heatsink on top of the CPU (don't move the heatsink after it makes touchdown) and fasten the other side of the metal clip so it's secure in place.
If you have doubts you can always remove it right after to see if the entire die area was covered by TIM and to see if you don't have a huge blob of TIM smeared across the substrate surface. And you can even practice with some old or cheap TIM and a spare junk CPU if you want to get the hang of it.
Reply 19 of 21, by imi
Tetrium wrote on 2021-11-11, 14:55:
Some years ago I was contemplating on whether it would be possible to disable part of the cache and make it work again if the ch […]
Yupp.
No post, no beep.
I don't believe it'd be simple as that, as there are probably many other lines routed around the outside of the die for connectivity
