First post, by etomcat
Hello,
I have this old Plus Development Corp. storage controller ISA card, which is marked as NEP-14T near the top edge, so I've always assumed that to mean the model name. But I've just saw a photo of the IBM PC Music Feature Card, which is marked NEP-16T near the top edge, as seen here: http://minuszerodegrees.net/5150_5160/cards/I … c%20Feature.jpg
So could this NEP-1xT thing be a generic marking for the number of layers within the PCB or something else? Maybe the marking has to do with the japanese electronics industry, since both cards were Made in Japan? If you have any info, please tell!
Thanks in advance, Yours Sincerely: Tamas Feher.
Reply 1 of 3, by quicknick
Resurrecting this, rather than create a new thread. Got one of these too, but I have no idea about its purpose. It's described in some places as Plus NEP-14T Epson SPFG ISA Parallel/Serial Adapter Board but really looks too complicated to be a Parallel/Serial board. Any clues?
Edit: external connector is a 37-pin male D-sub.
681.49 KiB
Reply 2 of 3, by Horun
Interesting card. There are some references to a "SPFG board" in the Epson Equity series manuals. They refer to it as having Floppy, serial and parallel ports.
The 34pin connector could be for a floppy. One thing interesting is the Sony chips are ram chips, the Mitsubishi chips are ROM chips, the NEC chip is a 8bit multiport microcontroller.
What is under the "104CBDxxx" label ? Is that an OKI chip ? If so it could for a specific printer/plotter and why has the odd 37pin external connector....
Reply 3 of 3, by quicknick
The chip under the label is a SMS OMTI 20513. Couldn't find much about it:
OMTI 3127A-3AA, Also SMS brand. SCSI to RLL adapter. Has 50-pin SCSI header, and 34 pin with two 20-pin hard drive […]
RLL header set. Has OMTI 20513 chip. No docs, not tested.
Google says up to two ST506/412 RLL 2,7 drives supported,
some jumper settings on the Web (Apr 2005).
(From here)
