First post, by Deczor
Hi guys, quick thing for those that might know, will this work?
Plug this into game port:
https://www.serdashop.com/DB15-Doubler-Solder-Kit
Plug this into one side:
https://www.serdashop.com/DB15MIDI
Plug joystick into the other side. I think it'll work since the doubler is simply paralleled and the midi circuitry will just go hang out by itself, but can it really be that simple?
Thanks 😀
Reply 1 of 5, by matze79
Should work with standard joystick as midi is on different pins
The attachment FF034616-2739-4C09-AB51-C6C724E20669.png is no longer available
Reply 2 of 5, by Deczor
Sweet! Thank you. Has to be a better solution than the ali Express cables.
Reply 3 of 5, by Shreddoc
Complicated by the fact that more advanced joystick (or digital gamepad) protocols - or even anything beyond "2 buttons for one player" - may repurpose the MIDI pins for their own needs, right?
The attachment deskauthority_scrnshot.png is no longer available
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 4 of 5, by Deczor
Hmm... Might have to cross that bridge after I burn it.
Reply 5 of 5, by Shreddoc
Deczor wrote on 2021-11-17, 04:28:
It's probably not as bad as I made it sound. Many setups will be ok. There merely exists the possibility of situations unfriendly to port-sharing.
