Yes, that is the exact model!
Thanks for the tips!
I've tried the reference disk, and actually it is the only disk the machine is willing to work with. Others, like dos boot disk/install disks do not work.
I have to run the config tool sc.exe.
I have tried this https://amigastore.eu/en/600-scsi-to-micro-sd-adapter.html with the machine just to check out if there is any way just to try is everything ok with the hardware. Diagnostic tests all worked without any problems. I guess 8556 is really picky with drivers as it seems I need to get every possible driver just to install dos and everything else, if I'm correct?
I have to take pictures of the devices the machine was installed with (micro channel bus cards, such as display adapters etc.) if anyone might know where I could possibly find the missing drivers.
This particular IBM model has been quite interesting as an on/off project, because I have randomly tried out to make it work, but I hope that I will get the machine working as it otherwise in perfect shape!
