First post, by Christian Knudsen
Hello!
I've downloaded DOSBox to test it with a DOS game I'm programming. The game is a textmode/console game programmed in Pascal (you can read more about it here: www.asciisector.net). I'd like to make some gameplay videos using DOSBox, but I can't seem to capture video. I can capture single .png screenshots using CTRL+F5, but when I press CTRL+ALT+F5 nothing happens -- there's not even a message in the console window, as there is when capturing screenshots. Is this simply because I can't capture textmode games/apps with DOSBox? I'm running DOSBox on a Toshiba Intel Pentium M 1,5GHz 496 MB RAM Windows XP laptop.
Reply 2 of 5, by Christian Knudsen
DosFreak wrote:
Are you running under a non-admin account?
No, I'm logged on as the administrator. (It's my girlfriend's laptop -- I'm not used to XP myself.)
Reply 3 of 5, by Christian Knudsen
I just tried running it on my old AMD K6 computer running Win98 and I had no problems capturing video of my textmode/console program. Of course the game was way too slow, but my test seems to indicate that the problem lies with WinXP...
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
check for programs that might be stealing that key combination
or use the mapper to map it to a differerent key (ctrl-f1 brings up the mapper)
Water flows down the stream
Reply 5 of 5, by Christian Knudsen
That did it! It works! Thanks!
