First post, by FFXIhealer
Ok, so long story short, I have a box of floppies and a couple of them simply won't format anymore - not on my Windows 10 USB floppy nor on Windows 95 or 98. I've checked multiple physical drives and OSes. It's not a hardware issue. It's the floppy.
Does anyone have ready access to any software that might let me COMPLETELY low-level format a floppy to see if I can recover the physical disk for use? Like, the ability to write a brand new track 1 sector index marker, etc.
I am also not opposed to finding a really strong magnet to pass over the floppies to see if that will get them to format. Right now, the problem disks just keep getting kicked out as "failed to format floppy" within Windows 95/98. And Windows 10 doesn't even give me the option to low-level format - only quick format. I HAVE been unchecking that box in Win95, so that's not my issue.
Thanks in advance.
Note: I DO have working floppies in my little floppy disk box, but I'm trying to recover the ones that AREN'T working because we all know how hard it is to find floppies now.
Reply 1 of 17, by weedeewee
fdformat tends to work quite well.
Do not ask Why !
Reply 2 of 17, by FFXIhealer
What is that?
EDIT: Nevermind - web searches are my friend. Looks like a Linux format program. The only Linux system I have running is my home media server and that computer doesn't have a floppy drive attached to it at all.
Reply 3 of 17, by weedeewee
https://github.com/christoh/fdformat
The first google hit for me when I type fdformat & dos, second if I only look for fdformat.
edit, I guess this link has the compiled version at the bottom of the page.
https://retrocmp.de/software/fdformat/fdformat.htm
Do not ask Why !
Reply 5 of 17, by Matth79
http://toastytech.com/files/nformat.html Nformat is the other one, both of them also have the ability to create "strange" formats like Microsoft DMF 21 sector, or to create optimized formats which skew on step so you don't lose a full rotation, typical optimized skew format is 3 for step and 0 or 1 on head switch
Reply 6 of 17, by Grzyb
There's nothing better than "format a: /u" under DOS.
All you can do is to run format several times - sometimes the media is slightly dirty, and it cleans itself while revolving.
I've seen many times when the first run of format resulted in some bad sectors, the second in fewer bad sectors, and another in no bad sectors at all.
But if this fails, then the hardware is bad, and no software can help.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść no moja górę, lecz i w tym, ze ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 11 of 17, by Grzyb
So I've been experimenting with a card marked "CONNER 2MB FLOPPY CONTROLLER"...
I got it to read and write from/to a 1.44 MB floppy connected to that controller, but couldn't do format - "Track 0 bad" error every time, with every diskette.
I don't know wheter the controller is defective, or just lacks this functionality - I got it with a tape drive, and suspect it may be designed especially for tapes.
Nevermind it for now...
The important thing is: I ended up with a few "defective" diskettes...
After going back to a regular FDC, I tried to re-format them using normal DOS "format a: /u", but it ended up with some bad sectors.
Then I went to another PC, running Windows 95 OSR2 with BootGUI=0, and again did "format a: /u" - same amount of bytes in bad sectors, every time!
Couldn't believe they all got damaged...
Formatted once again, this time using DiskDupe...
...no bad sectors at all!
After DiskDupe format, I did "format a: /u" once again - still no bad sectors!
All "defective" diskettes got "repaired", and work just fine.
Looks like "format a: /u" isn't totally unconditional, after all.
It may be a good idea to try with some alternative utility, before throwing out a "bad" floppy...
Reply 12 of 17, by wbahnassi
In my experience, FORMAT /U can't bring back disks with the error Track 0 Invalid Media, but ImageDisk can.
I had many disks that were like that and some others with bad sectors. I use Dave Dunnfield's ImageDisk under DOS and do a few rounds of the Erase Disk command, then go back to FORMAT /U /F:1.44 .. The disks come back to life, and even bad sectors get fixed after a few cycles of back-and-forth between Erase and Format (assuming no physical damage is on the media).
I also start my disk revival process with a media wipe using alcohol soaked microfiber, to rule out the effects of mold and dust on the media. Otherwise you might damage the drive if you keep feeding it dirty/moldy disks.
Reply 13 of 17, by Grzyb
I think various versions of FORMAT behave differently - but it may also have something to do with differences in hardware and/or BIOS.
Let me repeat myself...
Grzyb wrote on 2021-11-21, 17:36:
...but today, I experienced multiple runs of FORMAT resulting in exactly the same bad sectors count - clearly it didn't even try to re-format the area that was already marked "bad".
If the media is visibly damaged, the situation is clear.
If unusual noise can be heard - like repeated heads recalibration - then there must be something wrong with the media, but there's still some hope it's just dirty.
But if the media looks good, and sounds good, but FORMAT keeps ending up with bad sectors - the problem may be in the software...
Reply 14 of 17, by Disruptor
Have you tried VGACOPY to format disks? It tries to relocate sectory physically within the track, so you may have success with floppys that show track 0 error.
Have you tried to format disks in a LS120 drive?
Reply 15 of 17, by BitWrangler
I had one or two DD disks back in the day that soft corrupted, I'd stick them in the Amiga, format to Amiga 880K, format back to PC 720k with crossdos on Amiga, then stick them back in the PC can format /U again in DOS and they'd be back to useable. Never had a HD Amiga drive to see if it worked with 1.44 too... but I've since used dd on linux systems for same effect.
edit: DD is double density, dd is a linux util.
Reply 16 of 17, by Tiido
I have had an occasion where one drive was misaligned and I got multiple bad floppies on it that actually ended up being a drive issue. One time I had a drive that actually damaged discs due to some caked up gunk on its head...
But as far as super low-level format goes, I use a neodymium magnet stolen from a HDD. It makes even some actually bad floppies work for the duration of getting DOS or windows to install (and then hours later they start begoming unreadable again 🤣)
Reply 17 of 17, by Kahenraz
A few months ago I realigned a floppy drive head by hand. Part of the testing procedure including a full disk write and read. This absolutely put data in all kinds of weird and wrong places on the disk. I can confirm that I had a lot of corruption after the fact, but the disks were recovered just fine with a reformat in another machine. I couldn't use the same drive to format it, because I wasn't sure whether the heads were aligned yet.
Re: If you have a Compaq LTE series laptop with a broken floppy drive, check the belt!
