First post, by GeGnome
Hi guys,
I've been working on 20 or more 286-486 motherboards I picked up in a lot, and I have repaired all but a few.
I would really like to get this biostar mb-8433uud-a up and running, because it has a lot of nice features and support., and is likely the best of the bunch. This one is in immaculate condition with no apparent damage to traces, memory slots, no bulging capacitors, etc. Came setup with an AMD x586-P75, which ran fine at 160 MHz in another board. 80 ns RAM is also known working, but it acts the same even without RAM.
The Biostar board: https://www.win3x.org/uh19/motherboards/1075
Post codes 00 and C1 come up immediately at power up (all post card LEDs lit appropriately):
C1 is "Memory size checked", and perhaps it's getting stuck at this one?
I cleared the CMOS at JP12.
I have flashed the latest BIOS that Feipoa uploaded to a brand new EPROM, because I suspected that the original was bad, but there is no difference.
http://vogonsdrivers.com/getfile.php?fileid=947&menustate=0
I have double-checked all the jumpers and they all appear to be accurate for the cache, CPU settings, RTC operation, CPU voltage, multiplier, etc.
Would a dead RTC with the wrong CMOS settings cause this? I know that they can cause a lot of trouble. I would just take it out, but this one is going to be very difficult, and I don't have a desoldering station, so I am trying to rule out everything else first.
You guys are knowledgeable, and this board has a lot of support, so I would really appreciate your thoughts.
Thank you...
Reply 1 of 5, by Horun
Here is a couple of things: Do you have a speaker hooked up to listen for beeps ?
80nS 72pin simms probably will not work being that speed ram is more for 286 and early 386 boards also the board requires parity SIMMS (9 chip preferred over 3 chip)
Did you try it with a standard 5volt DX-2 to rule out the Vreg ?
Reply 3 of 5, by Horun
Deksor wrote on 2021-11-22, 01:26:
Make sure that your RAM isn't EDO but FPM ram instead.
Also don't use win3x.org now, we've moved to ultimateretro.net 😀
Yeah I forgot to mention those 😀
Reply 4 of 5, by treeman
When the rtc died on my 8433uud-a it still booted with low battery error.
I would try it at 33fsb, I have had 5x86 cpus that go 160mhz on some boards then on others won't boot at 40fsb only 33
Reply 5 of 5, by majestyk
This mainboard seems to have been exposed to moisture for a long time.
Look at the corrosion of the RAM retention-clips. I guess the contacts in the sockets look the same.
