Question on AGP ports
First post, by enaiel
Can AGP 8X video cards be used on a motherboard with an AGP 4X / AGP v2.0 compliant port? I know this has probably been covered a zillion times before, but I couldn't find a definitive answer.
Specifically, I have the following AGP 8X cards that I would like to use in that AGP 4X port:
  • MSI MS-8894 NVIDIA GeForce 4 Ti 4200 64MB Ti4200-VTD8X
  • BFG NVIDIA GeForce FX5500 256MB DDR 3DFR55256P
  • ATI Radeon 9600XT 128MB RV350
Thanks!
VIA C3 Ezra-T 1.0GHz / MSI MS-6368 / Voodoo2+ViRGE GX / SBPro2+YMF744+AWE64 / MT-32+SC-50
Pentium III-S Tualatin 1.40GHz / QDI A10T / Voodoo3 3000+GF4 Ti4200 / Audigy+AU8830
Reply 1 of 9, by kixs
Yes.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 2 of 9, by RaverX
Yes, it should work, the voltage is what matters. 99.9% if you can fit the card in the slot (without forcing it), it should work.
Reply 4 of 9, by enaiel
Thanks all for the quick responses!
Joseph_Joestar wrote on 2021-11-18, 14:14:
Here's a good read on AGP compatibility: http://www.playtool.com/pages/agpcompat/agp.html
BTW, be extra careful with AGP universal slots. They are sometimes not as compatible as they claim to be.
That's an excellent read! So, from what I understood, an AGP 3.0 card can potentially fit in an AGP 2.0 slot and not work, but only if it is not backwards compatible. And thankfully, all AGP 3.0 cards also support AGP 2.0.
As you said, the only problem is with a Universal AGP port that is only universal in slot and not in voltage - fits both AGP 2.0 and AGP 3.0 cards, but only supports the voltage for one of them. But that problem shouldn't apply to an AGP 2.0 port.
Great, thanks again!
Reply 5 of 9, by candle_86
some very late AGP 3.0 cards don't support the 1.5V from AGP 2.0 thats correct, It should be a very limited group of late ATI cards however that require .8V AGP 3.0, for 99% of AGP 8x cards they are 4x/8x and use 1.5/.8V AGP depending on slot. Some really late cards like the X1950Pro, HD3850, HD4650 ect may only support AGP 8x, but the thought behind it was more than likely only someone with an Athlon X2 in a 939 or Pentium D on 775 would be upgrading anyway and they are all AGP 8x
Reply 6 of 9, by Doornkaat
candle_86 wrote on 2021-11-22, 15:58:
That's the first time I hear of an AGP 3.0 card not being compatible with 1.5V/AGP 4x signalling. I was under the impression all commercially avaliable AGP 3.0 cards were actually universal 1.5V AGP 3.0 cards.
Can you give me a link or something to look into what exact cards aren't?
Reply 7 of 9, by candle_86
well i havn't seen an HD4650 that mentions AGP 4x compliant, they all say only AGP 8x which leads me to assume they require .8 V
Reply 8 of 9, by Doornkaat
candle_86 wrote on 2021-11-22, 18:09:
Thanks, I'll try and look into this. 😃👍
Has anyone got any experience with an HD4650 and AGP 4x?
Reply 9 of 9, by enaiel
According to Bjorn3D and a couple of other sites, the HD4650 supports AGP 8X / 4X:
And here's an Amazon review from someone who used it on an AGP 4X motherboard: https://www.amazon.com/gp/customer-reviews/R1 … ASIN=B002MLZPBY
