First post, by resle
I have never paid attention to forks of PCem and would always stick to the original in spite of purported improvements, extra features or whatever.
However given it seems development of PCem is not going to resume for the foreseeable future, I am now wondering about other options while hopefully someone takes over the repository.
Any you would advice, that stays as true as possible to the original?
(𝒕𝒉𝒆 π’Žπ’Šπ’”π’‚π’…π’—π’†π’π’•π’–π’“π’†π’” 𝒐𝒇 𝒅𝒓. π’˜π’“π’π’π’ˆπ’‘π’†π’“π’”π’π’ π’Šπ’ π’ƒπ’Šπ’•π’•π’†π’“π’•π’π’˜π’)
Reply 1 of 14, by Zup
I guess the only active? fork is 86box, but keep in mind that it was a result of some kind of disagreement from the direction PCem had and the vision that 86box was based.
So expect a fork that is not true to the original, although it has some capabilities that PCem lacks.
(OTOH another emulator aimed to be hardware-accurate is MAME, but that's a very complex and different beast)
I'm selling some stuff!
Reply 2 of 14, by resle
Zup wrote on 2021-11-01, 08:50:
I suppose I'll give it a try anyway, whereas am I correct that UNIPcem and Varcem diverge even more or aren't even forks of PCEm?
Reply 6 of 14, by resle
So, the executive summary is - 86Box only?
Reply 7 of 14, by AlexZ
These projects suffer from very low number of contributors. I'm surprised PCem even lasted that long. I don't really want any new features, I would be happy if the goal of 86Box was just to fix all the bugs reported in Github (and there aren't that many in comparison to e.g dosbox-x). People have their own lives and jobs, we can't expect contributors to work on it full time.
When I evaluated PCem vs 86Box half year ago I chose 86Box as the UI felt more refined and user friendly. Recently it got a new modern virtual machine manager called "WinBox for 86Box" with auto update capabilities. So for me suspension of the PCem project means no change.
I don't blame anyone for the split of PCem vs 86Box. Some contributors tend to have diverging vision for the project and it inevitably leads to a fork. Forking is not bad, it can lead to interesting clones like dosbox-x.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 8 of 14, by superfury
resle wrote on 2021-11-01, 10:28:
Eh, I remember the whole Battler / Sarah feud, but as a result of turning my ahead away from that, I can't say I know in which way(s) differ, or what the 86Box vision is supposed to be.
If you mean UniPCemu, it's not a fork of anything (although it's using a modified MPU-401 code from Dosbox because I can't find any documentation on it. It was a simple UART before that. Both were and are connected to the software MIDI synth I've built based on the Soundfont 2.04 specs). I've built it from scratch.
UniPCemu Git repository
Reply 10 of 14, by BitWrangler
Handy ref, not sure how up to the minute it is though .... https://emulation.gametechwiki.com/index.php/Intel_CPUs
Reply 11 of 14, by SortingHat
AlexZ wrote on 2021-11-13, 08:53:
Will 86box ever be able to use a live CD similar to PCEM Host CD option? That would be a BIG new feature!!!! Many games are copy protected such as Midtown Madness II which I use the real CD on PCEM to play or it will say 'Please Insert CD' if running ISO even an ISO from the same stupid disc!
Reply 12 of 14, by AlexZ
SortingHat wrote on 2021-12-04, 13:59:
Please create a feature request in Github. It would be a great feature. I'm not in any way associated with the project.
Reply 13 of 14, by Namrok
Did PCEM ever get this feature performant? Back when I tried to use it around V15 or so, it caused constant hitching and stalling as PCEM would ask the OS to read data from the drive, block, and then eventually receive it and go back to emulating. At least, that's what I thought was happening from looking at the code back then. At one point I wondered about trying to write some read ahead or buffering routines in there to smooth things out, but ended up just ripping ISOs of the games I cared about instead.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 14 of 14, by SortingHat
Namrok wrote on 2021-12-04, 20:20:
It's called HOST CD ROM on the menu.
It's the ONLY way I can play certain racing games that require the CD such as Mid Town Madness II/Midnight Club and Need for Speed High Streets I mean Stakes as it has copy protection on them. IE: It will say 'Please Insert Correct CD' when attempting to run the programs.
