First post, by BEEN_Nath_58
There is something wrong with InstallShield on my Windows 11 machine. A lot of games pre -2000 can be installed, but on 2nd installation attempt they can't be installed. I thought that they are 16-bit executables, in-fact OTVDM can run them, but I didn't install them with OTVDM on first place. The issue here is OTVDM can't run all InstallShield setups because of some missing files in it's system mostly relating to language (in my case) and thus fail.
Frogger 2 and Rainbow Six are example cases. I installed Rainbow Six directly from File Explorer on Win11x64 and it worked fine. Yesterday I go to the same process and now it says that the specified path doesn't exist. Today I was about to install Frogger 2 and the same error exists. However this error doesn't come up for NFS High Stakes from 1999, also using InstallShield. An odd thing here is that these InstallShields run on both 16-bit and 32-bit environments, allowing my WIN10 machine to run them from File Explorer and also OTVDM (of course not the ones I mentioned in the first paragraph). Some may be arguing that OTVDM will execute these 32-bit executables with a warning notifying that they are a Win32 application, but there is NO SUCH WARNING, so it has to be a 16/32-bit application (IDK how that works, Win32s?).
So what's wrong with InstallShield. You can see the attachment for the error I am receiving now.
