First post, by rmay635703
Back in the day when I was specing out my mid 1998 Era Mini Tower Computer Shopper special
I was cross shopping the Usual Cyrix offerings alongside the AMD K6-200 VRS
the new AMD K6-2 3dnow 200mhz
I initially considered the cheaper MII-pr300 but heard the 3dnow hype at the time and compared a variety of systems barebones to complete.
At the time I tried to get a new complete tower as far under $500 as possible
The price difference going from MII to K6 to K6-2 was quite large
I ended up with a
Vertex -AT Mid tower
MII - PR233
32mb SDRAM
24x cd
4gb hd
An irritating winmodem
Onboard sound
At the time it was immensely cheaper than even the MII PR300 offering and for our little craft business good enough for processing our custom poetry
Looking back, I knew lots of folks with regular K6 chips of all speed grades but rarely saw anyone with a baby k6-2, almost every k6-2 I saw in the wild was 333mhz+
Did anyone here own the base k6-2 over the normal k6? It looks almost like the slower k6-2 models were rare.
I remember considering upgrading my previous system to a low end k6-2 (previous to the 1998 special) but the cost of the chips early on and the fact my motherboard only went down to 2.5 volts made that option unattractive.
It also felt like vendors only wanted to sell regular k6 chips asking an unreasonable premium for the new k6-2.
I ended up selling the former system (at a small profit) and ended up keeping the 1998 special in the family straight through 2008 :0 a long time considering I was upgrading almost every year late 90’s.
Funny part is it seems like 6 months later a k6-2 450 was about the same money and you couldn’t find a k6 chip for sale above 233mhz.
Anyone else have this experience?
That was an interesting time nearing the point where the computer shopper mag died and you had to go on pricewatch.
Reply 1 of 10, by Anonymous Coward
I wanted a K6-2, but had just blown $400CAD on a K6-200 (just the CPU, not the whole system)...so no upgrade for me. K6-2/200 was definitely rare. Who would have wanted something that slow in 1998 anyway?
Maybe it would have been a good buy. You probably could have overclocked the hell out of it.
Reply 2 of 10, by rmay635703
Anonymous Coward wrote on 2021-12-11, 01:32:
I did because I needed to stick with a budget
Brand new a complete multimedia Pc $399 as spec’d even at the lowish speed for that time was a screaming deal.
I didn’t know what I know now and would have plaid loose with overclock ing but my experience was that only antique equipment seemed to overclock well, modern stuff had to stay reliable. The price difference early on for any k6-2 was too steep for my blood, that series topped out at 300mhz so maybe it would overclock but later k6-2’s never seemed to.
Riding the trailing edge meant I paid very little and could resell the system a year later (sometimes after an upgrade)
for what I paid (usually) and keep newish hardware without blowing a wad
Given I stuck with business software, internet , emulators and low end games it worked great keeping newer low end until about 2002 when everything fell apart and part quality became a$$.
Reply 3 of 10, by Sphere478
I find myself wondering what exactly the difference between some k61s and k62s were exactly because I noticed a interesting coincidence in my 266mhz specimens
Three basically identical chips, 266afr all same voltage, one a k6 one a k6-2 one ink marked, two a laser etched
Maybe I’ll plug them in one day and see what they say in cpu-z would have thought that the k6 and k6-2 would have a different letter after the speed or a different voltage at least??
Sphere's PCB projects.
Reply 4 of 10, by BitWrangler
Wow, I don't remember seeing any k6-2 slower than 300. My first K6 was actually the 266 core shrink. I got that running 300, then 333 when I got braver. 350 wasn't doable on that board, but seemed to be after it was retired on another board (didn't work it very hard) ... mostly I think though the pre CXT parts, 2 or not, hit a wall somewhere just over 350, if you get early 350s you can run them at 366 max 375 if you're lucky. Later 350s had a bit more slack, half of them would jusssst do 400 decapped, but run pretty hot doing it.
I think that AMD used the same volts/temp coding for several years, you might find a dx5-133 and K6-233 with the same code.
Don't know how slow the K6 went, I had only seen 200 to 300 before, though heard of a 333... then I saw a 166 and was mildly surprised they came that slow.
I believe I paid somewhere near $50 from Compgeeks for the 266 in early 99, then about 6 months later they had the K6-2-400 for under $50 so I grabbed one of those and ran it at 450. I got that whole combo together real cheap the motherboard was a $20 closeout.
Reply 5 of 10, by Sphere478
BitWrangler wrote on 2021-12-11, 05:00:
Wow, I don't remember seeing any k6-2 slower than 300. My first K6 was actually the 266 core shrink. I got that running 300, the […]
I can confirm the existence of these variants, There is a website around somewhere that lists all the different k6 variants (there are a surprising amount of them)
Reply 6 of 10, by Anonymous Coward
The main deal with K6-2 was 3Dnow, but that only made a difference if software was written to support it. K6-2 also benefitted from the die shrink on the 2nd wave of original K6 chips. I'm not aware of any other meaningful improvements.
Slow slowest K6 was the 166 (originally only available as 166 and 200 because 233 was harder to produce). I believe there were also die shrunk versions of the "K6-1" 166. Not sure about K6-2...maybe a mobile version?
Reply 7 of 10, by Tetrium
Anonymous Coward wrote on 2021-12-11, 05:28:
There were indeed die-shrunk K6 chips. There's even a K6-300 like this one here:
https://www.cpu-world.com/CPUs/K6/AMD-K6%2030 … -K6-300AFR.html
Not sure about a die-shrunk 166MHz K6 though.
My retro rigs (old topic)
Report spammers here!
Reply 8 of 10, by Sphere478
Tetrium wrote on 2021-12-11, 12:07:
There were indeed die-shrunk K6 chips. There's even a K6-300 like this one here: https://www.cpu-world.com/CPUs/K6/AMD-K6%2030 … […]
See, what’s up with the overlap, I literally have a k6-2 300afr in ink lettering but this one is a k6-1 with the same letters after the speed.
What do the letters mean I guess I should ask?
Reply 9 of 10, by BitWrangler
What, you didn't get your secret decoder ring? https://cpushack.com/K6xID.html
Reply 10 of 10, by Sphere478
BitWrangler wrote on 2021-12-11, 13:59:
Ooo! Printing that! Do you have that for pentium, cyrix, rise, ibm, st, winchip?
