First post, by the3dfxdude
I had a mini-ITX server computer that does not come up after a simple power outage. I narrowed the problem to the gigabyte motherboard. Looking for a replacement, current boards are going for about 3X what I paid for the board 6 years ago.
The symptoms are basically, the board looks to be in a permanent resetting state. The onboard speaker click every couple of seconds, and that corresponds to the test power supply fan spinning up and down in cycles. The original picoPSU supply appears to be fine. After going through some basic checks, I'd just write it off and get another eventually, but not at current prices.
I pulled out the system again to get the hard drive, but then decided while I was there I'd check for shorts on the supply rails at the power connector (without PSU attached). 5V and 12V look fine. But 3.3V is shorted to ground on my DMM in continuity mode. So I decided to check the caps. I found 5 caps next to the CPU exhibiting a short. There are two that have measured resistance of 6.8 ohm. The other three are around 40-50 ohm. The two 6.8 ohm caps are next to each other. In comparison, I checked another motherboard that is a full ATX sized board, and I measured 250 ohm between 3.3V and GND.
The caps on the gigabyte board are solid capacitors. They are from a manufacturer I cannot identify. There is a symbol with a larger C and a smaller c or dot in it. It does not appear to be nippon/chemicon to me.
So a few questions:
1. How low is too low for resistance between 3.3V and ground? Not sure how much can leak through modern chips.
2. What is the expected failure behavior of such solid caps? I have another gigabyte board, and it clearly uses Sanyo. So they are cheaping out on some of their boards anyway? Writing says
5KV30
C. 560
6.3V
3. Should I go for sucking the suspect caps out and see if that resolves the issue?
