Reply 20 of 25, by aitotat
I have one of these but I'm using MR-BIOS with it. The mainboard came with Cyrix DLC 40 but the DLC support seems to have problems. 386 works just fine.
That is some impressive performance 😮. I'm waiting to receive some eeprom to test XTide. It is required to use the DOS driver with XTide? Or XTide enables all the good stuff?
DOS driver must not be used with XTIDE Universal BIOS since the driver would reprogram the speeds and take over the disk I/O.
There are dumps from my card-Revision 2.1 - Promise BIOS is not on C800 address, but on D800 and it's size is 8k, according to what I found with Microsoft Diagnostics program from DOS 6.22. It's also included in ZIP archive.
Also found something interesting - Catalog of Octek products with specifications and jumper settings from August 1998 in Windows HLP format. Run included octeknet.exe in your retro machine (probably max with WinXP, in my retro laptop with 64bit Windows 7 refuses to run). In discontinued products are two versions of our Octek VL-COMBO card.
Tested the XTide ROM (386 8kb version) with the Promise controller, it went from 5.5 Mb/s using the DOS driver to 6.6 Mb/s without the driver. Not bad, I guess the CF is on the limit of it's performance.
hasat wrote on 2021-12-18, 10:46:Also found something interesting - Catalog of Octek products with specifications and jumper settings from August 1998 in Windows HLP format. Run included octeknet.exe in your retro machine (probably max with WinXP, in my retro laptop with 64bit Windows 7 refuses to run). In discontinued products are two versions of our Octek VL-COMBO card.
Great find!
BTW you can always use right-click -> 7-Zip -> open, if you have 7-Zip installed - this should also work on Win x64.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
