First post, by Lylat1an
- Member
I have an external SCSI CD changer that I'd like to use as a multidisc holder. (Because it appears as 7 separate drives in operating systems) But it doesn't want to eject the tray without being connected to a SCSI controller.
Is there a way I can make it think it's connected? Like maybe shorting a pair of pins?
It uses HPDB50 connectors if that helps.
