First post, by Kahenraz
I had ordered some memory from eBay and one of them had a missing SMD capacitor. But looks can be deceiving! With a close inspection under a microscope I also found that a second capacitor had also been damaged and was separating from the board.
It's impossible to know the correct value for SMD components but there was a good chance due to its location that the missing capacitor would match the value of the one which was damaged but still connected. I was able to lift the damaged component from the board and measure it with a capacitance meter to closely match 100nF (0.1uF). This was most likely the correct value even though it was slightly damaged.
Due to how ceramic capacitors are constructed in layers, the loss of a layer due to minor damage will not always cause a dead short but simply lower the capacitance. This is not always a guarantee so the component should always be measured and its value considered with good judgment.
132.88 KiB
188.88 KiB
227.15 KiB
62.47 KiB
Reply 1 of 3, by Kahenraz
This damaged and missing capacitor in this case was a 0603. The leftover debris was removed with some flux and a soldering iron tip and the pads were cleaned with a copper braid. The replacement components were affixed with solder paste and hot air.
I've only included photos for one of the capacitors as visually the other was pretty much identical.
After repair the module tested perfectly. 😀
196.87 KiB
203.46 KiB
306.59 KiB
Reply 2 of 3, by vstrakh
That should be the bypass caps. The exact value is not critical at all within reasonable range. It can be twice larger, likely will work ok even with twice smaller values. The ESR is what's critical with this application.
