First post, by Shernand
2 pics speak more than lots of words i belive 😉
Will post more later...
-- Shernand
Reply 1 of 8, by DosFreak
Nah, there was a patch for DosBox some time ago that actually implemented emulated NICS. Was never updated or incorporated tho. Only way to do it without programming a solution is to use modem like your doing above.
Make your games work offline
Reply 2 of 8, by eL_PuSHeR
WELCOME TO THE FORUM, Shernand.
Heh, your screen captures are full of JPEG compression artifacts. Next time use a lossless format like GIF or PNG, Luke. 😁
PD - ¿Otro español en el foro?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 8, by Shernand
You're both right, heheh, i just found out that i made it to work using the hardest possible way, but oh well, at least it was nice to write and send email from inside dosbox (using BBS server software) 😉
-- Shernand
Reply 5 of 8, by Shernand
Then here's 3 more pics for you Qbix, keep up the good work on DOSBOX and congrats in bringing back those memories!
Seeya,
Shernand
eL_PuSHeR - Si, soy de montevideo, uruguay 😉
Reply 6 of 8, by eL_PuSHeR
Pues mis más cordiales saludos para todos los Uruguayos. 😀
Best regards to all Uruguay people.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 8, by Shernand
Gracias igualmente para vos y la gente de tu país (De donde sos?)
Thanks, same goes for you and the people from your country (Where are you from?)
Reply 8 of 8, by eL_PuSHeR
España. Spain.
OK, let's get back on topic.
Intel i7 5960X
8 GB DDR4 (2100)
