First post, by Sphere478
The attachment image.jpg is no longer available
I’d like to call this a new build but as we all know parts swap between builds all the time and at some point you have a old build with new parts that you may as well call a new build. The conundrum of ulysses ship if you will, if you leave port and over the course of your journey replace every part did you return with the same ship?
Anyway.
Here are some links that I have referenced heavily during this build.
Re: K6-2/3+ Success on Asus P5A 1.06 - simple mod
Asus p5a cache upgrade!
Why is the Asus P5A so fast?
AMD K6 3DMARK, aiming for stars.
Looking for proof of existence of SS7 ALi chipset with 1Mb cache
Upgrading cache on Super 7 motherboards
Adding 3.3v to pci adapter(Released)
Asus P5A v1.06 - ALi Aladdin V with 1MB of Cache! (Full Review / Optimization Guide)
Adding More USB Ports to Retro Motherboards
And of course, pics!!
Sphere's PCB projects.
Reply 1 of 6, by Sphere478
The 1.04 board has been pretty straightforward no issues pretty stable with correct settings, even managed to get 120x5 working pretty good but the 1.06 board has been a total nightmare. Also had some issues with my radeon 9800 pro causing random freezes and restarts on all boards. Which took me a while to figure out because it would seem to work fine till the crash and it was my only agp card for a while.
Voltage blaster seems to work pretty good.
file.php?id=126841&mode=view
Even if I’m pretty sure nothing on my system is using -5v 🤣 except the light on the test card and the monitor in the bios
The attachment 1D0762BD-AE74-44B6-BB6B-2DE5B86D6212.jpeg is no longer available
I played around with the 1.06 board this evening but eventually gave up, there is something seriously wrong with it. It keeps rebooting like someone is bumping the power plug 🤣. I’ve reinstalled the 1.04 board and will probably just continue to use it from now on.
Reply 3 of 6, by Sphere478
1541 wrote on 2021-12-29, 10:17:
Here, someone stated that the Radeon 8000 would be the last supported card on this board: https://www.retrospace.net/infoseiten/ […]
https://www.retrospace.net/infoseiten/readm.php?id=2
Any more recent ATI card would cause issues.
Same with Geforce starting from Geforce 4.
https://www-retrospace-net.translate.goog/inf … &_x_tr_hl=en-US
In english
Reply 4 of 6, by BitWrangler
I read that as meaning the 8500 is too power hungry to use, therefore stick with the 7000s... BUT, I think the later shrinks of the 8500 like 9200, 9250 on universal AGP slot cards might be in with a chance of working okay, due to being a little less thirsty, but probably nothing further.
Reply 5 of 6, by Sphere478
BitWrangler wrote on 2021-12-29, 16:31:
My 5500 9250 and 9000 seem to be working fine on this board 1.04
Hidden jumper settings btw for p5a
Reply 6 of 6, by BitWrangler
Good to know the undoc settings thanks.
Now what motherboard was it that has 95Mhz bus, no PCI divider.. i.e FSB/2 divider... might be useful for pre-qualifying PCI cards that work at unsane PCI speeds... though I think you can find the odd NIC around that can do PCI-66.
