First post, by synarque
Hello everyone !
I seem to be the only one suffering from this problem ...
Machine :
Fujitsu-Siemens Amilo laptop
Intel Core 2 Duo 2*1.7GHz
Geforce Go 7600 (can't remember it's ram, 256 or 512 I guess)
2 Go ram
120 Go HDD
Using both DosBox 0.65 and 0.70
The problem I have is that when I am using fullscreen with Dosbox (either of the two version I mentionned), the keyboard gets all sluggish. I tried various settings possible, (with or without my usb keyboard, with minimum process environment, with dosbox.conf settings changed). Nothing seems to be efficient. Perhaps it is a common problem ? Though I really did not see any post about it.
And while I am at it, do anyone has solved Genewars problem with DosBox (I mean the horrendous land drawing, due to VESA) ?
And also, I seem not to be able to configure 0.70's windowed resolution, and as I cannot play fullscreen, I'm forced to use default 800*600 and it's really tiny !
I hope someone can help !
Thank you very much !
Reply 1 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You have to delete some file (recently there was another thread).
1+1=10
Reply 2 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
keyboard sluggyness: try to reduce the cycles Dosbox uses. When on default setting "cycles=max" it may happen (I think it did happen to me a couple of times) that keyboard input slows down. To reduce cycles press "Ctrl+F11" and see if that helps
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 10, by synarque
No it still does not change anything, no matter what the cycle number is. Besides, my keyboard input is fine if I'm in windowed version, so I believe it may not be a matter of processor but rather a problem with the video part of DosBox !
Reply 4 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
or a problem with your video card/driver
Water flows down the stream
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
No this is definitely no driver problem (we should have removed those
randomized heuristics in the keyboard controls).
Reply 6 of 10, by avatar_58
When I have keyboard problems I set dosbox to "normal" priority rather than the default "high". Thats for lagged input though, but it's worth a shot.
Reply 7 of 10, by synarque
Gave your method a shot, but still, it did not do the trick !
It's too bad because there are a lot of really fun games that uses keyboard only, and playing it on windowed mode is really not so fun !
eg bioforge who's laggy enough not to slow it down anymore !
And what a pain in the a.. not to be able to play the original Doom or Wolf3D fullscreen !
Reply 8 of 10, by wd
Rank DOSBox Author
DOSBox Author
So did you UPDATE THE GRAPHICS DRIVERS YET???
Reply 9 of 10, by synarque
Problem solved and excuse lme it had nothing to do with DosBox. I just bought Command and Conquer The last decade and I noticed that the keyboard was also sluggy in those games. So I did update my drivers, for nothing, this did not change anything. And then I thought a little more deeply and remembered that quake4's opengl did crash at launch because of some soft that was installed with my window's version : topDesk and UberIcon 😒
Killed the two processes forever, and the problems are gone ...
Sorry guys ---- Do never use those two dumb softs ... 😅
Reply 10 of 10, by wd
Rank DOSBox Author
DOSBox Author
Hm odd that it can have such an effect, thanks for reporting back!
