Many former chip fabs were scrapped, one larger Motorola fab and complex was gutted and scrapped.
One has to wonder since labor/ r&d is the main expense to making new masks if a late 90’s / 2k fab could be sourced and minimized for job lot production levels aka converted to a smaller process so you don’t pop hundreds or thousands of cores at once
MOS ran like a job lot for close to a decade, “testing “ a proto mask was $10,000 in just materials
gotta wonder if that could be translated to slightly obsolete fabs?
Clean Raw materials is a problem , size/power requirements of equipment the other .
Having the real deal would allow you to right size and burn custom silicon without resorting to expensive programmable logic.
Legal ramifications of just copying a core to use for hobby use should be controllable if you limit to 25 year plus designs .
