trident TVGA8900B
First post, by scroeffie
hi i had this vga card for couple of weeks now never tested it but it wont show anything
i have cleaned it reseat all the chips added new ram ,changed jumpers looked online for dip switch settings fixed 1 broken trace
nothing wont boot
any tips ?
Trident TVGA8900B FCC ID: HNG2YPTVGA96X8TC2
Reply 1 of 20, by weedeewee
missing 40MHz oscillator !
also, what do you mean with no boot, no image output and computer beeps two or three times ?
Do not ask Why !
Reply 2 of 20, by scroeffie
i have seen fotos online with same card but with the crystal but mine is pal or wont that matter ??
no beep from the speaker nothing on the screen i tested all the isa slots with other video cards and it works fine
changed jumpers and dipswitch settings from this site https://stason.org/TULARC/pc/graphics-cards/U … SUPER-8900.html
found this card on ebay from bulgaria and it has the crystal 40mhz https://www.ebay.com/itm/Trident-TVGA8900B-FC … 31800079?_ul=IL < same card as mine but mine has not the crystal very strange
Reply 4 of 20, by scroeffie
fgenesis wrote on 2022-01-01, 17:55:
I have this (or a very similar card) but no VGA bios chips... if possible, could you please dump those bios chips and upload the dump here? That would be great =)
i wil after i get it working 😀
Reply 5 of 20, by weedeewee
It looks like the crystal on your card was removed.
Do not ask Why !
Reply 6 of 20, by scroeffie
weedeewee wrote on 2022-01-01, 18:16:
very strange all the cards on ebay have that crystal mine doesnt wierd ! wil order a crystal than ! and see what happens
Reply 9 of 20, by Tiido
The card definitely has the oscillator cannibalized from it, there clearly was something in there and it has been desoldered. R2 looks to be removed too.
Reply 10 of 20, by Disruptor
scroeffie wrote on 2022-01-01, 18:40:
According to TH99 JP1 and JP2 are NOT sockets for DRAM modules
Instead you have to place some kind of jumper?
Setting JP1    JP2    J3
256KB Open Closed Pins 1 & 2, 4 & 5 closed
512KB Open Closed Pins 1 & 4, 2 & 5 closed
1MB Closed Open Pins 2 & 3, 5 & 6 closed
Note: The exact # of pins on JP1 & JP2 is unidentified by the manufacturer.
Reply 11 of 20, by scroeffie
Disruptor wrote on 2022-01-01, 18:56:
According to TH99 JP1 and JP2 are NOT sockets for DRAM modules Instead you have to place some kind of jumper? […]
Setting JP1    JP2    J3
thats possible dont have that jumper 😀 so i need jumper a crystal and ... i could pun in time metal legs on those jp1 jp2 sockets and jump one connection the other !
Reply 13 of 20, by Anonymous Coward
I wouldn't be so sure about that crystal being needed. Isn't the chip in U9 a clockgen? It might be that this card can be sold with either a clockgen or an oscillator.
Reply 14 of 20, by Grzyb
Anonymous Coward wrote on 2022-01-03, 13:50:
This one - http://vgamuseum.info/images/palcal/trident/8 … 900b_top_hq.jpg - has both the TCK9001N and the OSC1.
Reply 15 of 20, by Anonymous Coward
I just looked at the backside of the card. It does indeed look like someone screwed with it.
Reply 16 of 20, by scroeffie
iam stil trying to get it to work nothing ! i added red jumper things any tips
i have added a crytal but not shure if it works came out of a parts bin ! wil order a new crystal
    99.02 KiB
    99.03 KiB
    118.88 KiB
Reply 17 of 20, by scroeffie
I think the RAM I am using from AliExpress is fake! The computer beeps 3 times very fast, but still has a black screen. I have another of these cards but C revision, same thing - beeps 3 times fast.
Must be the fake RAM.
Reply 18 of 20, by vgeorgiev
scroeffie wrote on 2022-02-05, 17:17:
Hello,
Yes. They are.
I bought this https://www.aliexpress.com/item/1005004447026 … .429818021XVBUS and they don't work properly.
I used some other chips from scrap vga card and it worked.
By the way I am trying to make work my TVGA8900B too - same than yours. Do you have any info about the comfiguration of the switches next to the VGA port ?
I am getting "out of sync" on my monitor
